Epoxy
it should've been neither caulk NOR epoxy,,, most likely it probably was either polyurethane OR silicone - both are sealants & need to be installed correctly to result in acceptable service life,,, you can find info by looking at dow-corning's install directions which also notes the use of closed cell backer rod to prevent full adhesion as you only want joint sealant to adhere to the joint walls - good luck !
taxpayers voting for obama are as idiotic as chickens who voted for Col. Sanders ! To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
if you hear it from a guy in the apron store, be VERY suspicious the mtl/method will work,,, when it time to build something together, they won't answer phones NOR help To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
