Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 04-09-2012, 02:25 PM   #1
Embed Simpson bracket at angle
First post, concrete newbie.
I am pouring a patio/footing this week. There are several Simpson CB66 column base brackets that are to be embedded in the concrete. One of them is supposed to be at a 15 degree angle - the post attached to it is to provide lateral strength to the roof structure.
Any good ideas of how to get the angle measurement correct when the pour happens?
Thanks,
Paul
gravitypad is offline   Reply With Quote
Old 04-09-2012, 03:02 PM   #2
joed's Avatar
Put a 4x4 in the bracket and support the 4x4 with 2x lumber at the angel needed.
Do not PM with questions that can be asked in a forum. I will not respond.
What is/how can I find this type of bracket? (pic inside) ffrllc Building & Construction 5 07-26-2011 01:17 PM
Window A/C support bracket installation. Roy Rowlett Appliances 0 06-16-2010 11:25 PM
Tight drilling angle fw2007 Electrical 8 05-31-2008 10:33 AM
Staircase wainscoat angle DIYPRO Carpentry 5 04-08-2008 05:12 PM
Brick Veneer on steel angle iron sandyman720 Building & Construction 3 07-09-2007 09:21 PM
