Dusty Concrete Basement Floor - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 10-13-2013, 08:38 PM   #1
Rewards Points: 150
dusty concrete basement floor
I have lived in my house for over 2 years. I'm the original owner. The concrete basement floor is constantly dusty, like dry wall dust. I sweep it up and eventually is comes back. I forget about it and wind up tracking dust through the house. some people are unhappy??? any comment or suggestions on what might be causing this and how to stop it. thanks.
hpyjack2013 is offline   Reply With Quote
Old 10-13-2013, 08:50 PM   #2
Rewards Points: 13,300
It needs to be sealed.
Old 10-13-2013, 08:52 PM   #3
Rewards Points: 150
dusty concrete basment floor
ya think??
Old 10-13-2013, 09:31 PM   #4
Rewards Points: 3,418
Simple fix,just like Joe said.
Canarywood1 is online now   Reply With Quote
Old 10-13-2013, 11:44 PM   #5
Rewards Points: 150
really? what type of sealer? ya I know concrete sealer! after reading several of the posts in this forum some people (who actually sound like they know what they are talking about), suggest waiting several years before sealing. this is the first time I've encountered this after owning several houses and being an oil heat service man for over 25 years. ( a lot of heating systems start in the basement) If the top layer of concrete is dusting off what will the sealer adhere too?What's causing the dusting? not so simple is it?
Old 10-14-2013, 03:47 AM   #6
Rewards Points: 166
If you have cleaned the floor well and the dust comes right back then it may not have cured properly and will continue to be dusty. Usually it means that water (like rain) was allowed to stand on the surface when the concrete was troweled. If this is the case then the surface of the concrete is probably also soft and prone to scratches.
If it's new then see if it's under warranty and make someone else fix it. If it's not under warranty then a sealer can still be used. Sweep, wet mop, and dry thoroughly. Then apply a deep penetrating acrylic sealer.
dftc is offline   Reply With Quote
Old 10-14-2013, 07:13 AM   #7
PoleCat's Avatar
Rewards Points: 1,646
Acrylic floor finish.
"Ask me anything. If I don't know the answer I'll make something up."
PoleCat is offline   Reply With Quote
Old 10-14-2013, 07:30 AM   #8
Rewards Points: 150
Now that is an intelligent answer. thanks dftc.
basement concrete floor leveling ChrisWz Concrete, Stone & Masonry 7 03-20-2012 01:42 AM
Heat for a basement with Pellt Stove on Main Floor magnum44 HVAC 1 11-20-2011 09:55 AM
Creating a flat floor on an angled concrete floor? Magno Building & Construction 1 04-14-2011 06:42 AM
Painting Concrete Basement Floor techinstructor Painting 1 06-21-2010 07:29 PM
Concrete basement floor patching Village Man Flooring 4 09-16-2009 08:15 PM
