Dumptruck, On My Drive ? - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 03-17-2014, 07:42 AM   #1
Rewards Points: 236
dumptruck, on my drive ?
i am think i am going to need at least 1 load of something, for my new patio.
i would ideally like to have this load dumped right on the spot, so i have a lot less humping.
my driveway is 5y/o asphalt and in pretty good condition. i would like to keep it that way. so i am concerned about have a dump truck on my drive. and even more, have it pull off the drive, into the patio area, and busting up the edge of my drive. i think i would only need 1 load in a F-350 dump.
should i be concerned ?
Fix'n it is offline   Reply With Quote
Old 03-17-2014, 07:46 AM   #2
Rewards Points: 236
oh. and how about that same truck, going over a sidewalk ? grass on 1 side. the sidewalk is like new. but idk just how old it is, it looks new.
Old 03-17-2014, 09:12 AM   #3
MarginallyQualified
Rewards Points: 2,464
Buy/borrow a couple of wheelbarrows
then hire three or four people who own their own shovels.
Have a case of cold beer for the end of the day.
Old 03-17-2014, 09:58 AM   #4
Rewards Points: 256
As long as it is built right either option is fine. But whether it was built right is something you wont know until it is too late. Is the drive way raised higher than grass? You could add some blocking on grass and lay 2 2x12 from driveway to grass for tires .
JustinK is offline   Reply With Quote
Old 03-17-2014, 10:00 AM   #5
Rewards Points: 3,628
It doesn't make any difference how old the sidewalk is, it won't look like new when that loaded dump truck rolls over it.
Canarywood1 is online now   Reply With Quote
The Following 2 Users Say Thank You to Canarywood1 For This Useful Post:
gregzoll (03-31-2015), joecaption (03-17-2014)
Old 03-17-2014, 10:06 AM   #6
World's Tallest Midget
Mort's Avatar
Rewards Points: 692
An F-350 dump truck will be no problem. By your thread title I was thinking a Kenworth, which still would probably be okay unless your asphalt driveway is really crappy.
If you're concerned, you can get some 3/4" plywood and lay it down over the sidewalk where it contacts the grass. It doesn't sound like it would do much, but it helps spread out the load over a wider area. It worked a bunch of times for my 80k# mixer, so a 10k# F-350 should be a cakewalk.
I hate signatures.
Mort is offline   Reply With Quote
The Following 2 Users Say Thank You to Mort For This Useful Post:
Fix'n it (03-17-2014)
Old 03-17-2014, 05:58 PM   #7
Yeah Mort's right,that's the standard practice for a heavy delivery anywhere inside the curb line,sometime it works and sometime it doesn't,your call.
Old 03-17-2014, 07:47 PM   #8
Rewards Points: 236
thanx fella's. thats about what i thought.
but it now has me wondering. would they refuse to go past the curb ?
i know going up the drive would be ok. when i moved in i had a LARGE straight truck in the drive, that was filled with my stuff.
and i would do this when the ground is dried out. its soaked now.
i'm just planning ahead.
Old 03-17-2014, 07:49 PM   #9
MarginallyQualified
Nope. But they'll be sure you know the risk is on YOU.
You're not talking all that much material.
wheelbarrows, shovels, laborers, beer.
Old 03-17-2014, 07:58 PM   #10
Concrete & Masonry
Rewards Points: 576
We have a 5 yard dump truck, we've taken it through hundreds of yards and over just as many sidewalks and driveways for the last 15 years w/o incident. A small dump is twice the weight of a 4x4 pick-up truck, but it's sitting on 2 more tires to spread the weight out. As long as it's not soggy like you mention it is now, you'll be fine.........
jomama45 is offline   Reply With Quote
The Following 3 Users Say Thank You to jomama45 For This Useful Post:
Bondo (03-19-2014), Fix'n it (03-17-2014)
Old 03-18-2014, 09:52 AM   #11
landfillwizard's Avatar
Rewards Points: 516
I think that driving on the driveway would be fine but I would do what Mort said and lay down plywood over the sidewalk. You really don't know what or how thick a base they used to construct the sidewalk.
landfillwizard is offline   Reply With Quote
Old 03-19-2014, 10:33 AM   #12
Mort's Avatar
Rewards Points: 692
I've never once refused to drive over a curb, however, they could make you sign a liability waiver. It just means if their truck breaks the curb or gets stuck, it's on you. Some guys would get huffy with me, I'd just tell them it was my good luck charm, I hardly ever roll the truck over when I get one of those signed.
I hate signatures.
Old 03-19-2014, 11:29 AM   #13
We had liability waivers printed on the back of our delivery tickets, describing everything that might happen,and who was responsible for it if it did happen,sign the waiver and we would be happy to do anything within reason to make the delivery.
Old 03-19-2014, 11:56 AM   #14
Rewards Points: 2,062
That 3/4 ply is cheap insurance to protect the drive or sidewalk, and can be saved for later to use on another project.
WIN/WIN, in my opinion.
ED
de-nagorg is online now   Reply With Quote
Old 03-24-2014, 10:05 PM   #15
Rewards Points: 152
Have you considered a helicopter delivery? Iv had 6 yrd concrete trucks roll up on asphalt and concrete driveways no problem. Just DOOOOO it.
TRUEPRO is offline   Reply With Quote
garage door chain drive to belt drive pberm1962 General DIY Discussions 16 11-26-2011 08:28 PM
Satellite Rx external hard drive. Wildie PC Repairs & Upgrades 4 09-13-2009 11:06 PM
Moving C drive files Thurman PC Repairs & Upgrades 14 08-17-2009 03:13 PM
Hard drive redline PC Repairs & Upgrades 14 03-06-2009 04:27 PM
Vista sp1 won't load. drive won't restore sv9779 PC Repairs & Upgrades 42 01-11-2009 10:36 AM
