Driveway Slopes Towards House - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 05-19-2012, 03:38 PM   #1
driveway slopes towards house
Hello,
I have attached some pics of my driveway to show what's going on. As you can see it has a pretty good slope towards the house, which obviously isn't good. The house is over 30 years old, so i'm assuming the driveway is roughly the same age. No idea when it started to do this..could have been a year after it was poured for all I know.
Anyway, i'd appreciate some input as to what might be the best way to repair this. Removing/replacing the whole driveway isn't really possible at this point, but i'll still look into it.
The 2nd pic is a close up and shows how much it has sunk on that side, it originally would have been touching the parging on the foundain wall.
Right now it's not a huge issue, no water gets in the basement whatsoever. The driveway still has a good slope towards the street, so most of the water makes it's way out.. though there are sometime some shallow pools that stay temporarily against the foundation.
Any thoughts?
bseries4life is offline   Reply With Quote
Old 05-19-2012, 06:57 PM   #2
MarginallyQualified
Rewards Points: 2,464
Originally Posted by bseries4life View Post
As you can see it has a pretty good slope towards the house...
Right now it's not a huge issue, no water gets in the basement whatsoever... Removing/replacing the whole driveway isn't really possible at this point, but i'll still look into it.
Yeah, eventually you'll HAVE to demo the concrete and fix the underlay gravel and likely some drainage too.
The sooner the better so start saving up some cash.
In your favor is that 90% of the work involved is purely bull labor with that made easier by using easily rented heavy equipment. Start planning the work and organizing your budget and maybe lining up your healthy strong friends (tell them it's a weekend BBQ event).
Plan to have a pro concrete team do the actual finishing work.
hth
Old 05-20-2012, 09:43 AM   #3
Rewards Points: 216
does the basement leak on that side of the house ?
Fix'n it is offline   Reply With Quote
Old 05-20-2012, 09:47 AM   #4
Ravenworks's Avatar
You could put a curb in to channel the water for now or jack it,but replacement is best for the long haul.
U.S.M.C. "80-84" E.O.D. 1369
Ravenworks is offline   Reply With Quote
Old 05-20-2012, 10:48 AM   #5
Rewards Points: 1,440
You are probably okay if quickly you pour three gallons of water on that part of the driveway and the shallow pools "overflow" and water almost immediately starts running down to the street.
That means that only a small amount of water actually accumulates there and needs to be absorbed by the ground against your foundation.
And in this situation you can get away with caulking the joint where the driveway and foundation meet, the purpose is to retard (not fully eliminate) the seepage of water going down into the ground there and instead more water runs to the street.
AllanJ is online now   Reply With Quote
Old 05-20-2012, 12:00 PM   #6
Concrete & Masonry
Rewards Points: 520
A concrete curb could work, as long as it was sealed to the driveway for the most part.
You could also look into having it mudjacked, as a professional in the industry should be able to tell you if they can do it next to the foundation or not......
jomama45 is online now   Reply With Quote
Weird wiring in house fdmillion Electrical 13 06-14-2013 07:49 PM
Concrete Driveway - Asphalt Over Top? mark2741 Building & Construction 1 03-22-2011 04:42 PM
Questions about jacking up house to replace rotted rim/sill SolidStateS15 Remodeling 10 03-22-2010 12:43 PM
HVAC for c. 1956 House. What would YOU do? David911 HVAC 10 02-08-2010 06:58 PM
Patio roof to house attachment question mikemobile Building & Construction 1 09-30-2008 08:51 AM
