Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 02-17-2012, 07:40 PM   #1
Driveway sloped toward garage, floods garage in heavy rain.
Hello,
At my wits end with this problem...
To make a long story short, where my driveway and garage meet is the lowest point on my property and my entire front yard slopes toward the driveway so in heavy rain it ends up flooding my garage. When I first moved in there was just a small grate with a basin below and after the first rain storm I knew that wasn't going to work.
So what I did was cut a 12" trench the width of my driveway and dug down 30". Then I lined the hole with weed barrier and filled it with washed gravel and finished it off with permeable pavers. Well come to find out this is not going to work either now I'm not sure what to do and I'm looking for suggestions.
The biggest issue I face is there is no where for me to drain it to a lower point, I think I'm going to need to install a pump somewhere..
Driveway sloped toward garage, floods garage in heavy rain.-2011-07-30_16.44.49.jpg   Driveway sloped toward garage, floods garage in heavy rain.-2011-07-30_18.26.34.jpg   Driveway sloped toward garage, floods garage in heavy rain.-2011-07-30_19.00.12.jpg
ckkone is offline   Reply With Quote
Old 02-17-2012, 07:57 PM   #2
creeper's Avatar
People with more know how in this will be along shortly, but I think you forgot the 4" corrugated weeping pipe
creeper is offline   Reply With Quote
Old 02-17-2012, 08:04 PM   #3
Stay-at-home GC
What area are you in? Heavy rain events like Florida or more like Arizona? Is freezing a possibility?
Can correctly identify Shinola 3 out of 5 times*
*Under ideal conditions
Some days, my Life needs a Rewind/Erase Button.
CplDevilDog is offline   Reply With Quote
Old 02-17-2012, 08:20 PM   #4
It was a dark and stormy
Yoyizit's Avatar
Your soil is not permeable enough.
Rainfall data for your area may help you size your 12V pump. You need to know the catchment area. 1"/hour in 100 sq. ft. is 8 cu.ft/hour = about 1 gpm. Lifting this water 3' takes at least a 5W motor. Add piping and some kind of water level switch and you're done.
Old 02-17-2012, 08:43 PM   #5
I think that is the main issue its mostly clay/sand. I live in Salt Lake City, UT and we don't get that much rain but tend to get downpours when it does..
Old 02-17-2012, 08:44 PM   #6
Heavy rains in Utah? Well what you for got to do is is put in the perforated pipe to let it move out and a way from the house to a sump and have sump pump there to pump out the water. Second thing to do is place a speed bump angled away from your house so the water runs a way from it. make sure it is at least a foot a way from the door. or the last most costly is jack hammer up the drive way and re grade it so it slopes a way from your house.
Nailbags is offline   Reply With Quote
Old 02-17-2012, 09:01 PM   #7
I didn't put a perforated pipe to basin becuase there is no where to put a basin. Take a look at the picture below and you can see on one side of the driveway is concrete stairs and the other side an enbankment with a retaining wall. There is no lower point to move water away to, but I'm open for any suggestions..thanks and keep them coming.
Driveway sloped toward garage, floods garage in heavy rain.-2011-07-30_17.45.50.jpg
Old 02-17-2012, 09:41 PM   #8
right were that cinder block is jack hammer that out put a sump pump in. and pipe the water in to your neighbors basement just kidding on the last part. but that is what you might have to do is place the sump right there and pipe the water some were.
Old 02-17-2012, 10:32 PM   #9
Trying to avoid that since that is the landing to the stairs for the main entry into the house.
What normally happens is water will pool in the middle becuase of the slope of the driveway toward the old drain, eventually if it rains hard enough and long enough it will make its way into the garage.
I had an idea to remove the center paver and replace it with a 12" x 12" catch basin with a 6" extension and put a pump in there to take the water out to the street.
The Following User Says Thank You to ckkone For This Useful Post:
Nailbags (02-17-2012)
Old 02-17-2012, 10:35 PM   #10
creeper's Avatar
Can you dig in under the retaining wall and continue under the sod and daylight it at the driveway
Old 02-17-2012, 10:37 PM   #11
that could work? just remember that water always finds it own level.
Old 02-17-2012, 10:49 PM   #12
No, beyond that is my neighbors diveway which is level with the sod so I couldn't do that without a pump.
Old 02-17-2012, 11:12 PM   #13
Consider regrading the front yard ( tereces ect) so it won't funnel
additional water to the drive.
I'd look for passive ways instead of relying on on a pump that
may be out of commision when a storm knocks out the electric.
High Gear is offline   Reply With Quote
The Following User Says Thank You to High Gear For This Useful Post:
CplDevilDog (02-18-2012)
Old 02-18-2012, 07:02 AM   #14
Stay-at-home GC
Are there gutters on the house? If there are do they have Rain Conductors that daylight out the back of the house? Thinking you might tap into them.
The 4" perf pipe in the gravel is a "nice to have" but not a "must have". The lower resistance of the gravel will allow it to drain as long as you put positive slope in your initial dig.
You should put filter fabric over the gravel so fines like sand don't clog the system.
Could (might have to) go under the sidewalk and into a dry sump. With infrequent rain you are describing it should be easy to calc the correct size.
Bad driveway patch and seal work fastfan Landscaping & Lawn Care 1 09-09-2009 09:14 PM
Driveway issues hbfl4 Landscaping & Lawn Care 7 03-21-2009 08:16 AM
Will heavy rain within the first 24hrs destroy my freshly seeded lawn? joeyboy Landscaping & Lawn Care 2 08-02-2007 07:07 PM
Driveway Pour Before the Rain.... Hages Building & Construction 1 04-18-2007 07:53 AM
Basement Toilet Floods Every Time It Rain Tmb9862 Plumbing 12 10-29-2006 11:16 AM
