Driveway Plantar/concrete Form - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 05-06-2012, 11:16 AM   #1
Driveway plantar/concrete form
I'm building a plantar off the front of the garage that will have a poured concrete interior with a stone veneer on the outside. The highest point will be 30" and the the narrowest point will be 24" across including the stone (2-2.5" thick stone). I'm trying to achieve the widest opening possible while maintaining a strong wall. The cap will be a poured concrete form (stained and sealed). What's the thinnest I can get away with for the vertical concrete?
run on dirt is offline   Reply With Quote
Old 05-08-2012, 09:22 AM   #2
Rewards Points: 152
4" would be the absolute minimum for any concrete application. I would prob go at least that to be safe. Plenty of rebar as well.
But since this is a planter, why dont you just pour a 8" footer, use 4" concrete block to build the walls, stick the stone right on the block and call it a day. Way less work then what your describing.
Good luck.
TRUEPRO is offline   Reply With Quote
How to repair a cracked driveway or walkway rfrick7@yahoo.c How To Guides 8 06-15-2015 04:59 AM
Driveway + Walkway buildup question r0yal Landscaping & Lawn Care 2 03-24-2012 09:42 AM
Bad driveway patch and seal work fastfan Landscaping & Lawn Care 1 09-09-2009 09:14 PM
Need to have driveway paved and graded Mikey Palmice Landscaping & Lawn Care 3 05-20-2009 08:07 PM
