Drilling Through Tile - Not What You Think - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 10-24-2013, 04:02 AM   #1
Question
Drilling through tile - not what you think
This probably isn't what you think. I successfully drilled through glazed ceramic tile in order to install a curved 90 degree shower curtain rod. So I did the research for the correct drill bits, techniques, bit cooling, etc. Got that accomplished just fine.
But.
The bit won't go any further after it has gone through the tile! I need around an inch to insert the anchor, but only getting through about 1/4 inch. Just through the tile but not what's behind it. Weird. I thought maybe I burned the bit out. It didn't look like it, but I tried a different bit, and same result.
I even tried a regular (non masonry) bit in case there's something back there that a masonry bit doesn't handle well. No luck.
I'm in Thailand, and so it's a concrete house--I think due to humidity they don't built with wood much. I expected to drill through tile and continue on in to concrete. But everything came to a halt after getting through the tile.
So I'm flusterpated and confusinated. Anyone have any ideas?
Thanks! (I'm hoping I chose the correct subject forum for this question)
Kirk's Girdle is offline   Reply With Quote
Old 10-24-2013, 04:38 AM   #2
MEASURE ONCE, CUT TWICE
123pugsy's Avatar
Rewards Points: 1,652
Did you hit some steel?
Pugsy.....my project: Total House Rebuild Bungalow to Two Story
123pugsy is offline   Reply With Quote
The Following User Says Thank You to 123pugsy For This Useful Post:
Kirk's Girdle (10-24-2013)
Old 10-24-2013, 04:51 AM   #3
That's all i can think of. Why there would be steel back there escapes me. I'm going to put a penlight in there and see if anything is visible.
It -is- near the window frame. But from what I can tell by looking at the window, I can't see that it would have a support embedded as far in as where I'm drilling. Or if it did, why it woud be thick steel... It's just a little aluminum shower/exhaust window.
Thanks for your reply and I'll let you know if I find something out!
Old 10-24-2013, 05:19 AM   #4
DIY staff
Rewards Points: 7,174
Try a magnet---good luck---
Old 10-24-2013, 09:11 PM   #5
Msradell's Avatar
Rewards Points: 350
Even if it is steel you should be able to drill through it with a good quality bit.
Msradell is online now   Reply With Quote
Old 10-25-2013, 04:29 AM   #6
Rewards Points: 4,806
IF its rebar, probably 3/8" min but more likely 1/2",,, IF you can hit it dead ctr, its ' drillable ' - off center & bits ' slide ',,, good luck !
Need advice in fixing "contractor's" botched shower floor tile job toocheaptohire Tiling, ceramics, marble 5 10-15-2012 02:31 PM
Tile over Painted Lightweight Cement New_2_DIY Flooring 16 08-28-2011 02:29 AM
new ceramic tile over 12x12 ceramic danthebuilder Tiling, ceramics, marble 4 08-09-2011 12:03 PM
Vertical tile on wall poolecw Flooring 2 06-01-2010 10:05 AM
Preping for ceramic tile install leroyme Flooring 21 11-29-2007 03:31 PM
