Drilling Into Stucco To Install Security Doors - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 07-29-2012, 07:12 PM   #1
Drilling into stucco to install security doors
Hi everyone. First timer here. Thanks for a great forum. I suspect this is an obvious question, but my attempts to search for this answer have turned up nothing.
I need to install metal security doors. The Home Depot guy says that all of their doors install by drilling into the house around the door frame. I have stucco that goes right up to the door (no trim). Do I need to somehow protect against water intrusion by using some sort of sealant or flashing? Or will the bolt itself close up the hole? I was planning to borrow a hammer drill to drill the holes. Any other advice is welcome. Thanks!
careyk is offline   Reply With Quote
Old 07-29-2012, 08:10 PM   #2
Rewards Points: 558
I know this is not stucco but it will give you an insight of what you need to do and the tools required for the job. http://www.diynetwork.com/how-to/how-to-install-a-pre-hung-exterior-door/index.html
epson is offline   Reply With Quote
Old 07-29-2012, 10:18 PM   #3
Thanks, epson. To update, someone else has advised that it probably doesn't matter but that if I really want to be safe, I could squirt some silicone caulk in the hole and on the bolt. I'll probably try that if nobody advises otherwise. Thanks again.
Old 08-03-2012, 09:32 AM   #4
Coconut Pete's paella!
CoconutPete's Avatar
Rewards Points: 504
What does a security door do?
CoconutPete is offline   Reply With Quote
Old 08-03-2012, 01:52 PM   #5
The thief used a crowbar to break the door frame, which is made of wood. A metal security door is something like this --
http://www.homedepot.com/Doors-Windo...kuId=202766477
It gets bolted to the concrete exterior with one-way screws. It consists of metal mesh welded to steel bars. To crowbar the door, the thief would have to first remove it or break it off from the house.
Tags
stucco water
want to install blinds on sliding doors joy0912 Interior Decorating 2 09-26-2007 07:18 PM
New exterior french door install in a stucco wall lightninrodman Building & Construction 2 06-30-2007 12:08 PM
When to Install Pre-Hung Interior Doors For New Construction Hages Carpentry 5 03-01-2007 10:34 PM
Install floating floor or my doors first? jtr Flooring 3 11-16-2006 10:21 PM
