Drilling Into Stone - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 06-14-2014, 08:02 AM   #1
Rewards Points: 145
Drilling into stone
I'm trying to attach a railing to my stone wall. The tapcon bit worked fine in the cement areas but now I have to drill completely in to stone. I read about renting a hammer drill but those start at 1/2 where I only need 3/16. Any suggestions? Or do I can I use an l bracket in to the cement? Needs to pass code.
kjmass1 is offline   Reply With Quote
Old 06-14-2014, 08:21 AM   #2
DIY staff
Rewards Points: 7,174
There are many hammer drills with standard jacobs chucks that will accept small bits--call your rental store and ask--if you see a need in the future--there are cheap homeowner models available for about $40--
Old 06-14-2014, 08:26 AM   #3
Rewards Points: 12,844
SDS style hammer drills have drill bits down to 3/16.
Old 06-14-2014, 01:03 PM   #4
Rewards Points: 4,454
far as i know, there're 3 sizes of sds chucks - sds, sds plus, & sds max,,, a bosch bulldog will do what you want but buy the bits @ the apron/vest store,,, in granite, buy more than 1 we use sds 3/16" often in the bulldog,,, oh'mike forgot to add ' cheap tools are never a good buy ! ' if you don't need it in the future, rent it !
we NEVER hammer-drill w/jacobs chuck - loosens too often !
irc
Old 06-14-2014, 01:45 PM   #5
DIY staff
You are right---cheap drills have a very short life---however,disposable cheap-os have their place---often ,for a homeowner,buying a cheap one will be less than renting--and get the job done---
Old 06-14-2014, 01:48 PM   #6
think our local guy gets $40 day for a bulldog h/d - can 1 buy something as cheap as that, mike ? tnx
irc
Old 06-14-2014, 02:54 PM   #7
Rewards Points: 145
I found a dewalt dw511 for $20 on craigslist...think it would get the job done?
Old 06-14-2014, 03:07 PM   #8
Pro
Rewards Points: 91
For drilling into granite I use a small diamond abrasive bit from the tile supplier - they're like a mini-core bit. They do make them that small, they're much faster and easier than a carbide-tipped bit, and they work in a non-impact drill. The last one I bought was around $20.
Robert Cram
Robert Cram Construction
CarpenterSFO is offline   Reply With Quote
Old 06-14-2014, 04:14 PM   #9
Rewards Points: 3,358
Or if the rental is more than the price of this, just get a Bosch bit and your good to go, they also have a very liberal return policy.
http://www.harborfreight.com/variabl...ck-to-top-link
Canarywood1 is online now   Reply With Quote
Old 06-14-2014, 05:36 PM   #10
Carp, do you use water on the bits ? they sound interesting - apron/vest stores have 'em ? tnx
irc
Old 06-14-2014, 09:24 PM   #11
DIY staff
irc
I buy those on Ebay (from Hong Kong) 10 for $15---yes ,you must keep them wet --on walls, I drill through a sponge first--wet the sponge and press as you need water---
I get about four holes through porcelain before they are junk---some times more---
Old 06-14-2014, 09:57 PM   #12
that's where i get blades & bits, too - this item ? http://www.ebay.com/itm/141109397113...113%26_rdc%3D1
irc
Old 06-14-2014, 10:13 PM   #13
DIY staff
diamond core drill 1/4" | eBay
The Following 2 Users Say Thank You to oh'mike For This Useful Post:
kwikfishron (06-14-2014)
Old 06-17-2014, 12:10 PM   #14
Concrete & Masonry
Rewards Points: 470
That's ingenius!!
jomama45 is offline   Reply With Quote
Old 06-17-2014, 05:07 PM   #15
mike's in illinois, NOT in genius !! just found out viri-zeus is the mythical god of communication,,, always thought it was mercury
irc
Interior stone veneer fireplace: what should I do at drywall? ScooberJake Concrete, Stone & Masonry 6 04-13-2014 10:38 AM
Making a Mantle for a Stone Fireplace. Two Knots Building & Construction 10 10-24-2013 06:53 PM
The Stone Veneer Is Falling Off JulieMor Concrete, Stone & Masonry 30 09-29-2013 11:00 AM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 05:08 PM
