Drilling Holes In Concrete Not Working, What Now? - Concrete, Stone & Masonry - Page 2 - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 06-14-2012, 08:54 PM   #16
DIY staff
Rewards Points: 7,174
Originally Posted by anuvanoob View Post
LMFAO!!! Turns out I did have a hammer drill -
Is there a better masonry drill bit than Tapcon? Is there a way to prevent bending and snapping of the drill bits?
The best commonly available masonry bits---Bosch--Lennox--
Stay away from the cheap ones--they fail quickly--
Old 06-15-2012, 03:49 AM   #17
Rewards Points: 178
Picked up a new shorter Tapcon drill bit and I successfully drilled my all holes (6 total) in less than 2 minutes. I ran into a couple of areas that were tough to drill through so I had to pick new spots.
Lessons learned: use a hammer drill, use better quality drill bits and don't be stubborn and waste 4 days trying to drill in a spot that's obviously not drillable
Thank you everyone. Very much appreciated!
anuvanoob is offline   Reply With Quote
The Following User Says Thank You to anuvanoob For This Useful Post:
oh'mike (06-15-2012)
Old 06-15-2012, 09:31 PM   #18
thanks for letting us know how this ended
terry603 is offline   Reply With Quote
Fix Drill Holes in Concrete Foundation Wall jdusling Building & Construction 8 08-26-2011 11:31 AM
Drilling in concrete wall spatrick Building & Construction 15 08-03-2010 07:09 PM
Proper methods to fill concrete gaps, holes, cracks and resurface concrete jzam42 Building & Construction 6 07-21-2010 12:50 PM
Drilling into concrete walls klycklama Building & Construction 4 02-09-2009 04:07 PM
Engineering help request: drilling holes in a deck joist, supported by a post Deck Building & Construction 14 05-31-2008 11:16 PM
