Drilling Holes In Concrete Not Working, What Now? - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 06-13-2012, 12:03 PM   #1
Rewards Points: 178
drilling holes in concrete not working, what now?
I'm trying to drill a hole in the concrete basement floor so I can fasten a bottom plate to it and I'm not having much luck. I've successfully drilled one hole already, but I'm not getting far with this next one - I was advised to be patient when it comes to concrete drilling, but I think this is taking much longer than normal.
I'm using a Tapcon concrete drill bit, 3/16" x 5 1/4", and Craftsman 19.2v 1400 rpm power drill. Do I need a more powerful drill? Could the drill bit have gone dull from the first hole? Is there a cheaper yet effective alternative method to fastening the bottom plate to the concrete floor?
anuvanoob is offline   Reply With Quote
Old 06-13-2012, 12:24 PM   #2
Rewards Points: 1,298
Move your hole over a little. You may be hitting a piece of re-bar.
danpik is offline   Reply With Quote
Old 06-13-2012, 12:28 PM   #3
does that drill have a hammer effect?
terry603 is offline   Reply With Quote
Old 06-13-2012, 12:38 PM   #4
MarginallyQualified
Rewards Points: 2,464
^^This.
With a hammer drill and a good masonry bit you should be fine.
(I prefer Bosch and with tapcons to use 1/32" smaller hole than suggested)
Is there a... effective alternative method to fastening the bottom plate to the concrete floor?
Powder actuated (if you have the tools)
Old 06-13-2012, 01:42 PM   #5
Rewards Points: 33
looks like you're using a normal drill. use a hammer drill and a good masonry bit and you will drill the hole in less than a minute. if theres a harbor freight tool nearby, you can get it fairly cheap.
bionictony is offline   Reply With Quote
Old 06-13-2012, 02:54 PM   #6
Rewards Points: 502
[quote=anuvanoob;942542] I think this is taking much longer than normal.
One of these might do it quicker
tony.g is offline   Reply With Quote
Old 06-13-2012, 11:26 PM   #7
Rewards Points: 178
I tried several different spots with no luck.
No, but I do have an impact drill (2400 rpm/3500 bpm) but it doesn't take drill bits, just regular bits (Philips, flat head, etc.)
Originally Posted by TarheelTerp View Post
^^This.
Why smaller? Unfortunately I don't have access to a powder actuated tool thing.
are hammer drills and impact drills not the same? what BPM and/or RPM should I look for? what brand or type of masonry bit do you consider "good" (so far I've used a Tapcon and Skil drill bit, both not having an effect anymore)?
Old 06-13-2012, 11:27 PM   #8
Rewards Points: 178
[QUOTE=tony.g;942648]
What is the exact name of that and about how much does a good one cost?
Old 06-14-2012, 06:25 AM   #9
Two completly different animals. Impact drills/drivers "hammer" the bit in a rotational motion. This is why they are good for loosening stuck bolts/screws and are actually no good for drilling. Hammer drills, when rotating, have a mechanism that causes the bit to move in a linier motion while it is turning. This motion moves the bit in and out of the hole in a motion that allows the bit to clear the bottom briefly and them impacts back against the bottom briefly. Part of the issue you may be having also is the fact you are using a cordless drill. I rarely ever have good luck drilling masonry with batteries. I use a 1/2" drive hammer drill made by Makita and can drill tapcon holes all day on one bit.
Old 06-14-2012, 06:33 AM   #10
Rewards Points: 502
[quote=anuvanoob;943072]
Sorry, anuvanoob, I was only joking. You may not have seen the tool in the sketch but it is an old hand-brace (sometimes known as an auger).This is what we used before power drills became available - you just turn the cranked handle, by hand, and its very slow! I still have my own brace (a Stanley) which was my fathers. and its now nearly 60 years old but still comes in handy when slow drilling is necessary, and you can also put screwdrive bits in it to really tighen up screws when a lot of torque is required.
Enough history. You should be using a hammer drill for concrete. Most DIY drills (Bosch, Makita, DeWalt) have a hammer-drill setting (strictly, they are known as percussive drills; true hammer drills are heavier and not usually used for DIY).
Are you using the correct drill bit? Masonry drills usually have tungsten-carbide tips (see pics) which do occasionally need sharpening. As a previous poster said, you may have hit a bar, or possibly a very hard piece of stone - try drilling nearby. Smetimes, it works by drilling a small pilot hole, and then using a wider bit to open it up, though be careful as the drill can snatch.
Hope this helps and good luck with it.
drilling holes in concrete not working, what now?-mini-dscf3628.jpg   drilling holes in concrete not working, what now?-mini-dscf3629.jpg
Old 06-14-2012, 07:22 AM   #11
Bill Kearney
Rewards Points: 1,174
Tony is right. Use a hammer drill with masonry bits. Makes all the difference. First time I'd ever used one was after wasting time using a masonry bit in a regular drill. Barely any progress. With the hammer setting (corded 1/2" capable hammer drill) it drilled out the hole literally in seconds. I've got a dewalt 18v with a hammer setting and it 'works' but it's nowhere near as quick as the job the corded one does.
wkearney99 is offline   Reply With Quote
Old 06-14-2012, 10:09 AM   #12
Rewards Points: 268
You should be able to rent a rotary hammer at your local tool rental store. They usually come in a case with an assortment of masonry bits. If not, rent a bit also. The bigger ones have a different shaft and are called MDS or MDS plus. These corded drills will make fast work of the holes you need to drill.
packer_rich is offline   Reply With Quote
Old 06-14-2012, 06:18 PM   #13
Rewards Points: 178
LMFAO!!! Turns out I did have a hammer drill - I thought it was a regular ol' big drill! It truly does make all the difference in the world! Unfortunately the Tapcon drill bit snapped twice and is now bent. The Skil drill bit got red hot and it's tungsten-carbide tips burned off. I may have hit a piece of stone or re-bar which sucks because I seems like I keep running into this issue everytime I move further down my chalk line (I gotta drill along it or face starting this project over). The good news is the concrete basement appears to be thicker than 3/4" as I originally feared.
Is there a better masonry drill bit than Tapcon? Is there a way to prevent bending and snapping of the drill bits?
The Following User Says Thank You to anuvanoob For This Useful Post:
oh'mike (06-14-2012)
Old 06-14-2012, 06:26 PM   #14
Framing Contractor
Rewards Points: 120
Like some have posted, go rent an sds drill and buy a good sds bit. The bit is about 8 bucks and will do a lot of holes very quickly. You really don't need a lot of tapcons to hold each plate in place. Typically, I like one at each end, and one every 4' or so. Always nice to put one at each side of the door openings as well.
sixeightten is offline   Reply With Quote
Old 06-14-2012, 07:27 PM   #15
Haverhill Trade 1965
[quote=tony.g;942648]
If you have the hammer you tap on the top of this with you could try fluted masonry nails. Like we used back in BC .
Duckweather is offline   Reply With Quote
Fix Drill Holes in Concrete Foundation Wall jdusling Building & Construction 8 08-26-2011 10:31 AM
Drilling in concrete wall spatrick Building & Construction 15 08-03-2010 06:09 PM
Proper methods to fill concrete gaps, holes, cracks and resurface concrete jzam42 Building & Construction 6 07-21-2010 11:50 AM
Drilling into concrete walls klycklama Building & Construction 4 02-09-2009 03:07 PM
Engineering help request: drilling holes in a deck joist, supported by a post Deck Building & Construction 14 05-31-2008 10:16 PM
