Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 09-20-2012, 12:58 PM   #1
Drilling ceramic tile
Hoping someone can tell me what I did wrong here.. I used this drill bit on a porcelain tile last week as a test. I taped the surface, cooled it with water and drilled through it with no problem on my drill press.
Last night I started my job, got to the first hole and couldn't get the hole drilled without breaking tiles. (These are different tiles than I used on my test run, naturally ) I could get about 1/8" through my 3/8" tile and get stuck. I tried flipping a couple over and still got about 1/8" before the bit would just stop cutting and start squeaking.
First things first, I'm going to slow the drill down when I try tonight. But is there anything else I should be doing differently?
Edit: Porcelain, not ceramic.
qoncept is offline   Reply With Quote
Old 09-20-2012, 02:16 PM   #2
That's the wrong bit for porcelain tile.
Look for a diamond bit that's made for porcelain tile.
Lowe's #48295 is a cheap one that probably won't last long but would most likely get you through if you're not drilling a bunch of holes.
ktkelly is offline   Reply With Quote
Old 09-20-2012, 02:37 PM   #3
Thanks, I thought I had the right thing. I need to make holes about an inch though, for copper pipes. Would I be better off using a dremel with a cutoff tool?
Old 09-20-2012, 05:56 PM   #4
You should just get a larger version of that same diamond bit I mentioned. It's really a "core drill bit".
The 1 1/2" one I had was for drilling "dry" and it worked quite well fro me.
I used it in my drill press and used slow steady pressure. I do mean slow, as it'll build up a lot of heat. Push too hard or fast and the tile will break.
Ask me how I know...
Old 09-20-2012, 07:07 PM   #5
Super Moderator
KTKELLY is right--a diamond hole saw is what's needed---and water---there are some useable ones at the Depot and places like that---they will come with a plastic stick on cup that acts as a guide and a water reservoir.
ceramic tile stain kivy Flooring 10 04-09-2012 07:57 AM
Tile over existing ceramic tile jgb29 Tiling, ceramics, marble 4 03-26-2012 12:50 PM
Could use some help on ceramic vs duraceramic tile helpmike Flooring 17 03-29-2011 11:42 PM
Replacing Ceramic tile floor handy andy Flooring 4 03-28-2011 01:07 AM
Cutting ceramic tile away from bathtub Tomgrillo Tiling, ceramics, marble 2 03-24-2011 12:04 AM
