-   Concrete, Stone & Masonry (http://www.diychatroom.com/f105/)
-   -   Drilling ceramic tile (http://www.diychatroom.com/f105/drilling-ceramic-tile-157411/)
qoncept 09-20-2012 11:58 AM
Hoping someone can tell me what I did wrong here.. I used this drill bit on a porcelain tile last week as a test. I taped the surface, cooled it with water and drilled through it with no problem on my drill press.
Last night I started my job, got to the first hole and couldn't get the hole drilled without breaking tiles. (These are different tiles than I used on my test run, naturally :eek:) I could get about 1/8" through my 3/8" tile and get stuck. I tried flipping a couple over and still got about 1/8" before the bit would just stop cutting and start squeaking.
First things first, I'm going to slow the drill down when I try tonight. But is there anything else I should be doing differently?
Edit: Porcelain, not ceramic.
ktkelly 09-20-2012 01:16 PM
That's the wrong bit for porcelain tile.
Look for a diamond bit that's made for porcelain tile.
Lowe's #48295 is a cheap one that probably won't last long but would most likely get you through if you're not drilling a bunch of holes.
qoncept 09-20-2012 01:37 PM
Thanks, I thought I had the right thing. I need to make holes about an inch though, for copper pipes. Would I be better off using a dremel with a cutoff tool?
ktkelly 09-20-2012 04:56 PM
You should just get a larger version of that same diamond bit I mentioned. It's really a "core drill bit".
The 1 1/2" one I had was for drilling "dry" and it worked quite well fro me.
I used it in my drill press and used slow steady pressure. I do mean slow, as it'll build up a lot of heat. Push too hard or fast and the tile will break.
Ask me how I know...:laughing:
oh'mike 09-20-2012 06:07 PM
KTKELLY is right--a diamond hole saw is what's needed---and water---there are some useable ones at the Depot and places like that---they will come with a plastic stick on cup that acts as a guide and a water reservoir.
