Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 09-29-2012, 06:28 PM   #1
Drilling 1 1/2" hole through cinder block
I need to run conduit through my exterior wall of which I assume is cinder block (not sure how to tell if it's cinder vs concrete block). The outside diameter of the conduit is 1 and 1/2". I have access to a hammer drill but the largest bit from Home Depot/Lowes that I can find is 1". My questions.
1) Can I use the 1" bit and widen the hole with it and not risk damaging the wall?
2) What should I use to seal around the conduit if needed? Spray foam or a specific type of caulk? I'm hoping I don't have to... there is an LB fitting going inside on either side of the wall, so if I drill it just right it should be covered by the fittings.
3) Any general tips for the drilling?
Thanks!
BrandonD is offline   Reply With Quote
Old 09-29-2012, 09:07 PM   #2
Super Moderator
I suggest you use a 1/4" bit and make a bunch of holes--then knock the plug out with a cold chisel----
Old 09-29-2012, 09:17 PM   #3
That's the way I do it, but I use a 3/8 bit so it last longer. Also make sure to drill the hole from the outside not the inside. The block under the house may blow out some and not look as good.
I use Hydrolic cement to clean up and seal it.
oh'mike (09-29-2012)
Old 09-29-2012, 09:54 PM   #4
Super Moderator
I only mentioned 1/4" because I always seem to have a bunch of that size--I use the for wall anchors ---
Old 10-01-2012, 08:57 AM   #5
Thanks for the tips. I believe the guy I'm borrowing the hammer drill from already has 1/4" or 3/8" bit too, so that saves me from buying a bit!
The Following User Says Thank You to BrandonD For This Useful Post:
oh'mike (10-01-2012)
Old 10-01-2012, 09:07 AM   #6
sdsester's Avatar
If you wanted it pretty, you could step up to a carbide or diamond tipped hole saw for masonry and stone just larger than diameter you are running through it.
sdsester is offline   Reply With Quote
Attaching patio cover to the top of cinder block wall robertwallace Building & Construction 7 07-10-2012 11:22 PM
Removing White Powdery Substance From Cinder Block Lawrence Coppar Concrete, Stone & Masonry 5 04-12-2012 03:28 PM
# of rebar in cinder block wall johnlvs2run Building & Construction 3 08-08-2010 11:48 AM
Wire through cinder block Red Squirrel Electrical 9 07-04-2010 05:45 PM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 05:08 PM
