Drill Close To Concrete Edge - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 10-09-2013, 08:13 AM   #1
Drill Close to Concrete Edge
Hi,
We've recently had a pool cover installed. The cover requires anchors drilled into the concrete pool deck. The manufacturer recommends drilling 6 inches from the edge but the contractor has installed some of the anchors about 1- 1 1/2 inches from the edge. I see no signs of chipping or cracking now but could this cause problems in the future?
Thanks.
jbdanis is offline   Reply With Quote
Old 10-09-2013, 01:16 PM   #2
GBrackins's Avatar
Rewards Points: 2,108
I was taught that you needed a minimum of 2" from the edge of the anchor to the edge of the concrete so that would be 2-1/4" for a 1/2" anchor.
it may not have any affect with what they did, just keep an eye on it.
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old 10-09-2013, 07:04 PM   #3
43 years in construction
Arkitexas's Avatar
The distance to the edge of the concrete is a function of the depth of the anchor. Expansion anchors apply force to the concrete in an inverted cone beginning at the bottom of the anchor. Ramset assumes the cone area to have 45* sides, thus if the anchor is 1.5" deep then it should be no closer than 1.5" from the edge of the concrete, or 4" from the edge if 4" deep. Even using this rule of thumb, be aware that concrete is typically weaker at its edges because of the faster evaporation of water during the curing process and typically less-than-optimum placement techniques and troweling.
Rick
Arkitexas is offline   Reply With Quote
Old 10-10-2013, 03:49 PM   #4
Rewards Points: 502
Have they used expansion fittings, or could they have been resin-fixed?
tony.g is offline   Reply With Quote
The Following User Says Thank You to tony.g For This Useful Post:
GBrackins (10-10-2013)
Tags
concrete , crack , drill , edge
Taper Concrete edge to concrete edge?? rebelranger Concrete, Stone & Masonry 17 11-27-2012 10:47 AM
Using regular drill for tapcon concrete screws? crayola110 Concrete, Stone & Masonry 5 10-10-2012 03:41 PM
concrete under pavers around pool deck , pavers go to edge of pool doggie44 Landscaping & Lawn Care 0 02-27-2011 10:40 AM
Attaching bottom plate to concrete at edge near wall BlueBSH Building & Construction 13 06-13-2010 04:05 PM
Crumbling Front Porch - Part 2 - The Repair jerseyguy1996 General DIY Discussions 9 04-11-2010 06:11 AM
