Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 07-14-2012, 03:48 AM   #1
dried mortar on stone
What is the best home solution to get dried mortar off of stone ?
Weedwacker is offline   Reply With Quote
Old 07-14-2012, 07:42 AM   #2
The usual way to remove OPC mortar staining is a dilute solution of hydrochloric acid This is available as a proprietory solution at builder's merchants or DIY outlets. It is simply brushed on with a scrubbing brush, and then washed off with water.
Some stones and bricks can be discoloured by the process and it is best to try it on an inconspicuous part first.
tony.g is offline   Reply With Quote
Best mortar mix for stone veneer heinlein0311 Concrete, Stone & Masonry 10 03-29-2012 08:00 AM
Help!!! Stone veneer type s mortar failure activa Building & Construction 4 12-04-2011 08:11 PM
Field Stone and Mortar Wall, will it be stable? NorskeDiv Landscaping & Lawn Care 4 07-14-2011 11:18 AM
Stone wall problem with mortar weberus3 Building & Construction 22 01-06-2010 09:06 AM
