Does This Seem Safe? - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 04-18-2013, 09:10 PM   #1
Rewards Points: 948
Does this seem safe?
I realize it is tough to give a meaningful answer when you can't actually see it, but I am totally clueless here.
My house has a 4' high stone breakwall at the lake about 10" thick. It is on a concrete footer. It is made of grapefruit sized rocks cemented together. It is probably about 60 years old. I would like to bolt two large hooks onto it and store a 60 pound kayak on it. Is that likely to be okay? It would be really nice to do, but I expect fixing the wall will be expensive.
There is a set of stairs attached to it with a pair of hinges. They used plastic inserts and screws. It seems to be pretty solid; is that the right way?
Toller is offline   Reply With Quote
Old 04-18-2013, 09:17 PM   #2
Rewards Points: 13,300
Really need that picture.
Plastic anchors to hold up a gate.
Old 04-18-2013, 10:04 PM   #3
Rewards Points: 626
Photo please!
Nailbags is offline   Reply With Quote
Old 04-18-2013, 10:38 PM   #4
GBrackins's Avatar
Rewards Points: 2,108
i think a few photos may be in order ....
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old 04-19-2013, 01:49 AM   #5
JOATMON
ddawg16's Avatar
Rewards Points: 1,172
I understand exactly what your talking about.....
Your big concern is how deep the footing is. But, if it's not leaning....I think your going to be ok.
But....a 60lb kayak? 60lb? Is that one of those 3 person jobs? If it really does weigh that much...time to buy another one. I would think a 45lb carbon fiber one would fit the bill....
ddawg16 is online now   Reply With Quote
Old 04-19-2013, 11:15 AM   #6
Rewards Points: 948
Okay, here are pictures.
The first three are of the wall where I want to hang the kayak.
The fourth one is of one of the hinges now attached to the wall.
The last two are of the wall on the other side of the dock. This wall is 14" thick and appears to be better construction; however there are no stairs going to it; so it is much less desirable than the first wall.
Carbon kayaks would be very light, but if I am leaving it at the water that is not much of an advantage. They are 3 times the price and much more fragile; so I will stick with plastic.
Old 04-19-2013, 01:53 PM   #7
Master General ReEngineer
Bondo's Avatar
Rewards Points: 650
Ayuh,..... If it were Me,...
I'd bend up some Huge "S" hooks outa, say 1, 1/2"x 1/4" flat stock steel,....
If ya didn't mind the toe-stubber on top of the wall, ya could use Rebar, 'n slip an ole hose over it to protect the yak...
I'd run the flat stock over the top of the wall, 'n sink the tag end of it 6"/ 10" deep into the turf, behind the wall....
Over the face, bend hoops to match the kayak, at whatever elevation ya choose.......
That way, ya ain't gotta drill Any holes in yer ole antique stone wall,...
which appears to be holdin' up, quite well...
If ya do go with some sorta brackets needin' screws, 'n holes,...
Drill all yer holes on a slightly upward cant so's they'll drain of water, 'n use Tapcons for screws...
Water settin', 'n freezin' in the winter can destroy rock, 'n concrete...
Bondo is online now   Reply With Quote
Old 04-19-2013, 02:33 PM   #8
Rewards Points: 948
I have a brass kickplate that I have been saving for 15 years for something. If I can figure out how to cut it in half, that might work. (sure, a jigsaw would work, but it would be slow going) On the outside I could hammer a 4x4 into the ground and use the hook to keep it attached to the wall, and attach the hooks I already have on the 4x4s. Would the footer for the wall be thicker than the wall?
Old 04-20-2013, 06:35 AM   #9
Rewards Points: 4,538
a hacksaw & metal blade will make quick work of sawing the brass,,, you could even rent an elec power'd jig saw for faster time figuring out how to cut in 1/2 could require a tape measure & magic marker
' On the outside I could hammer a 4x4 into the ground and use the hook to keep it attached to the wall ' - what does THIS mean ?
no one knows about the footer or IF there is 1,,, those guys got paid & they're gone a simple test to determine the strength of the wall would be TO SIT ON IT,,, if you weigh more than the kayak & the wall doesn't fall over, i bet the wall's strong enough might try that test in several locations just to be sure !
ps - IF my post yesterday was offensive, a moderator removed it !
Old 04-20-2013, 07:42 AM   #10
Rewards Points: 948
There has to be a a footer; the waves would have undermined it the first year it was up without one.
I an sure any number of people could stand on it; that doesn't mean it will take the torque of having a kayak hung on it, or take screws.
Old 04-20-2013, 11:35 AM   #11
Bondo's Avatar
Rewards Points: 650
Ayuh,.... Yer Over-thinkin' this,....
yer hangin' a Kayak, not a Battleship....
Old 04-20-2013, 11:59 AM   #12
Rewards Points: 81
Go with the kevlar, save the carbon fiber for the paddles.
one cut is offline   Reply With Quote
ShieldsUP! (staying safe on the internet!) DangerMouse PC Repairs & Upgrades 3 07-08-2012 10:40 PM
Wondering if this is safe? skylesjk Electrical 10 06-29-2011 06:53 PM
No combination for safe aminus21 Building & Construction 3 03-16-2011 08:32 PM
safe way to add extension to power cord sil Electrical 7 10-18-2007 10:58 PM
Gun Safe vs. Floor Joists allen1466 Building & Construction 9 03-03-2006 09:16 AM
