Does This Look Like Wood Burning Fireplace? - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 05-06-2013, 04:45 AM   #1
Rewards Points: 452
Does this look like wood burning fireplace?
It has a keyhole for gas on the left, but not sure if it can burn wood too.
Does that chimney look like it's capable?
House was built in 60's.
pman6 is offline   Reply With Quote
Old 05-06-2013, 04:52 AM   #2
Too Short? Cut it Again!
Looks like it could handle a small woodburning fire but best to have it inspected and the chimney swept if it has not been used for awhile. The fact there is not sign of soot on the white brick suggests it has been used mainly as a gas fireplace? Or the valve could be for a gas starter? You are prone to earthquakes so you want to make sure the chimney has not cracked.
The size of the firebox is really out of scale for that massive amount of brick. Hard to tell from the photo how deep it is? I think if somebody built it with that much masonry and what looks like a ceramic chimney it was meant to burn wood at one time.
Fireplaces are really nice I think but most not at all energy efficient. In fact, their drafts can suck warm air right out the chimney. Worse with woodburning than gas. Toss some "campfire memory" incense in the thing for the smell.
Old 05-06-2013, 12:19 PM   #3
747
registered
747's Avatar
Rewards Points: 534
Thats a good looking fireplace from the inside. At a minimum get a chimney sweep guy to have a look.
747 is offline   Reply With Quote
Old 05-06-2013, 05:04 PM   #4
An old Tradesmen
Rewards Points: 6,590
Moved to masonry forum.
what wood burning inserts can fit into a Heatilator EC36 prefab fireplace shela Building & Construction 1 03-15-2013 05:17 PM
Fireplace reno help, wood to gas fireplace jsunsun Building & Construction 4 01-15-2013 09:09 PM
Replacing a wood with a direct vent fireplace Travlnman Building & Construction 0 07-25-2011 07:31 PM
How Much Savings From Burning Wood? sweaty HVAC 9 01-22-2011 04:52 PM
Wood burning stove trim not flush against chimney Fortitude Appliances 1 11-11-2010 10:28 PM
