Diy - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 06-16-2014, 01:23 PM   #1
Diy
i'm laying a flagstone patio about 10 x10 with walkway and brick edging....i'm planning on putting a 4" base down first with compacted crushed stone! i'll compact 2" at a time to make sure the surface is completed solid before laying flagstone. I was wanting to mortar flagstone to the compacted stone to keep from moving and then mortar the joints between stone.
Has anyone done this before and did it last a while?
thanks,
lionscorp
lionscorp is offline   Reply With Quote
Old 06-16-2014, 02:07 PM   #2
JOATMON
ddawg16's Avatar
Rewards Points: 1,956
Welcome...it's been done but I don't think you need to go that far.
Do your 3-4" of compacted stone....then 2" of sand on top of that...screed it real well using a 10' 2x4'. If you wet it as you go you compact the stand real well.
I have 6"x 6" pavers....NO movement at all. The stone goes a long ways to giving you a stable base.
They make a sand for filling in the cracks. You spread it out....pack it in with a broom...and then when you wet it....it pretty much turns to cement.
Old 06-16-2014, 03:09 PM   #3
Rob
Robpo's Avatar
Rewards Points: 826
I have never heard of compacting stone in two lifts. I would think it would mesh better if you went over it longer with one lift instead.
Robpo is offline   Reply With Quote
Old 06-16-2014, 05:17 PM   #4
Concrete & Masonry
Rewards Points: 616
I've never heard of wet laying flagstone on a gravel bed, however I have set them in stone dust and mortared the joints with decent success. The joints have cracked and moved a little through the years, but it did it 10 years ago. That said, it was only at my own house, I don't think I'd use this method at a customer's residence........
jomama45 is online now   Reply With Quote
Old 06-16-2014, 05:53 PM   #5
Rewards Points: 3,718
thanks,
lionscorp
I don't think i'd mortar the flagstone to the stone bed, and instead of mortar for the joints, i'd use polymeric sand.
Canarywood1 is offline   Reply With Quote
Old 06-16-2014, 09:37 PM   #6
Msradell's Avatar
Rewards Points: 258
That would be my choice also.
Written using Dragon Naturally Speaking
Msradell is offline   Reply With Quote
Old 06-16-2014, 09:53 PM   #7
Rewards Points: 1,232
Robpo is completely out in left field, pay no attention to him.
There are 2 kinds of pavements:
Rigid, such as a wet laid flagstone on a concrete slab with appropriately specified mortar filling the joints.
Flexible, such as flagstone laid in a crushed stone bed on leveling sand with joints filled with either sharp sand or aggregate based upon the joint size, or a polymeric aggregate filling the top section of the joint.
Any mix of the 2 will lead to failure of either the mortar joints between the rock, or failure of the bedding material.
Advice is free, Lessons begin at 75 bucks an hour.
Tscarborough is offline   Reply With Quote
Old 06-17-2014, 08:52 AM   #8
Lionscorp
Thanks guys for all your input on the flagstone issue! The main reason i was going to wet lay the flagstone on crushed stone is for one to save customer money and not pour concrete and two there's about 12 foot of
existing sidewalk that i'm mortaring flagstone onto. I wanted to come off
the sidewalk and continue with flagstone patio which if i first compacted it
solid then wet lay the flagstone it would have a better chance of not moving
in future with mortared joints as well.
The edging will be done in brick around sidewalk and patio to give it more depth and stability.
your thoughts!
Lionscorp
Old 06-17-2014, 03:52 PM   #9
You are trying to blend a flexible pavement system with a rigid one. It will fail, simple as that. Pick one or the other.
Old 06-17-2014, 05:13 PM   #10
Rewards Points: 582
http://www.pavingexpert.com/pccflag1.htm
stuart45 is offline   Reply With Quote
Old 06-17-2014, 07:51 PM   #11
Stuart, that is not flagstone, it is pavers.
Old 06-17-2014, 09:18 PM   #12
Rewards Points: 236
a word of caution. polymeric sand has issues, sometimes. google it first.
Fix'n it is offline   Reply With Quote
Old 06-17-2014, 10:12 PM   #13
It doesn't have issues, it is mis-used. When used within specifications it or almost anything will perform as advertised. As with the original poster, when you ask a design to perform beyond it's specifications, it will fail. The shame is that the product is then blamed for the failure, even though it was not used within it's design envelope.
Old 06-18-2014, 03:59 AM   #14
Rewards Points: 582
yes sorry, wrong page. Scroll down to laying flagstones, it's a reaaly big website.
Old 06-18-2014, 08:44 AM   #15
This is what is known in the US as "flagstone":
http://www.pavingexpert.com/crazypav.htm
And as you can see, they list 2 types of bedding for this, just as I described above, although even 10:1 sand:cement is not really good.
The Following User Says Thank You to Tscarborough For This Useful Post:
stuart45 (06-18-2014)
