05-20-2012, 11:07 AM
#1
Discolored concrete patio
The previous owner left white paint spots all over the concrete porch and as you can tell the concrete is getting very discolored from over the years. I used my pressure washer yesterday, but that didn't do much. What's my best approach to make this area look better?
05-20-2012, 11:58 AM
#2
Concrete & Masonry
The paint drips will likely need to be scraped by hand. I would suggest a much more powerful pressure washer for the balance, along with a cleaner like bleach or any of the commercial cleaners available.
05-20-2012, 12:03 PM
#3
The paint drips are 7-8 yrs old though. Can't do it.
05-20-2012, 12:07 PM
#4
Concrete & Masonry
Sorry I guess I can't help you then, as I have no idea what this word means. I was brought up by a Father who told me that word didn't exist and should simply be replaced with "I don't want to because I'm too lazy"......
Try harder and scrape the paint off........
The Following 2 Users Say Thank You to jomama45 For This Useful Post:
05-20-2012, 12:13 PM
#5
Sorry I guess I can't help you then, as I have no idea what this word means. I was brought up by a Father who told me that work didn't exist and should simply be replace with "I don't want to because I'm too lazy"......
Sorry I should have said the 10 attempts I have made to scrape it off have proven to be unsuccessful.
05-20-2012, 01:11 PM
#6
what about concrete stain?
05-20-2012, 02:18 PM
#7
I think the OP is overly concerned about the condition of something that existed when the property was bought years ago. I would have been much easier to correct then since it may have been a paint job just before the home was listed.
I don't think the "staining" of the concrete is related to the paint spots. Staining might help since it can produce a variable appearance.
Dick
05-20-2012, 02:19 PM
#8
Dick
Should I something like paint stripper or formia/muratic acid?
05-21-2012, 08:23 AM
#9
Concrete & Masonry
Any kind of translucent/transparent/opaque stain is still going to allow the existing variation in color show through, plus it would certainly need a cleaner substrate than you currently have to bond sufficiently. If a solid-colored stain is what you desire, they certainly have issues of their own, and you're still going to need to clean the stains better.
I wouldn't recommend using muriatic on the stoop either, as it will cause even more color issues. A paint scraper with some elbow grease should remove the paint splatters in short order. If not, a simple, safe product like "Goof-Off" or the like should help soften them enough to scrape off.
05-21-2012, 10:46 AM
#10
Heat gun. It'll remove paint that is older than dirt.
Or ... simply more elbow grease.
The Following User Says Thank You to Rewound98 For This Useful Post:
05-21-2012, 10:51 AM
#11
What's the best kind of paint scraper to try? In the past I believe I tried doing this without success. I can try again.
05-21-2012, 11:28 AM
#12
What paint scraper would be the best?
05-21-2012, 12:10 PM
#13
try a razor scrapper.
DIY'er, out of necessity. if i did this for a living, i would make about $3.50 an hour To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
i didn't make this world. i just live in it.
be careful of whom you make fun of. one day, that could be you...
05-21-2012, 12:47 PM
#14
Tried that with no luck.
05-21-2012, 06:37 PM
#15
Wouldn't paint stripper be my best option here?
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
