-   Concrete, Stone & Masonry (http://www.diychatroom.com/f105/)
-   -   Discolored concrete patio (http://www.diychatroom.com/f105/discolored-concrete-patio-144321/)
dinosaur1 05-20-2012 10:07 AM
2 Attachment(s)
The previous owner left white paint spots all over the concrete porch and as you can tell the concrete is getting very discolored from over the years. I used my pressure washer yesterday, but that didn't do much. What's my best approach to make this area look better?
jomama45 05-20-2012 10:58 AM
The paint drips will likely need to be scraped by hand. I would suggest a much more powerful pressure washer for the balance, along with a cleaner like bleach or any of the commercial cleaners available.
dinosaur1 05-20-2012 11:03 AM
The paint drips are 7-8 yrs old though. Can't do it.
jomama45 05-20-2012 11:07 AM
Sorry I guess I can't help you then, as I have no idea what this word means. I was brought up by a Father who told me that word didn't exist and should simply be replaced with "I don't want to because I'm too lazy"......
Try harder and scrape the paint off........
dinosaur1 05-20-2012 11:13 AM
Sorry I guess I can't help you then, as I have no idea what this word means. I was brought up by a Father who told me that work didn't exist and should simply be replace with "I don't want to because I'm too lazy"......
Sorry I should have said the 10 attempts I have made to scrape it off have proven to be unsuccessful.
dinosaur1 05-20-2012 12:11 PM
what about concrete stain?
concretemasonry 05-20-2012 01:18 PM
I think the OP is overly concerned about the condition of something that existed when the property was bought years ago. I would have been much easier to correct then since it may have been a paint job just before the home was listed.
I don't think the "staining" of the concrete is related to the paint spots. Staining might help since it can produce a variable appearance.
Dick
dinosaur1 05-20-2012 01:19 PM
Dick
Should I something like paint stripper or formia/muratic acid?
jomama45 05-21-2012 07:23 AM
Any kind of translucent/transparent/opaque stain is still going to allow the existing variation in color show through, plus it would certainly need a cleaner substrate than you currently have to bond sufficiently. If a solid-colored stain is what you desire, they certainly have issues of their own, and you're still going to need to clean the stains better.
I wouldn't recommend using muriatic on the stoop either, as it will cause even more color issues. A paint scraper with some elbow grease should remove the paint splatters in short order. If not, a simple, safe product like "Goof-Off" or the like should help soften them enough to scrape off.
Rewound98 05-21-2012 09:46 AM
Heat gun. It'll remove paint that is older than dirt.
Or ... simply more elbow grease.
dinosaur1 05-21-2012 09:51 AM
What's the best kind of paint scraper to try? In the past I believe I tried doing this without success. I can try again.
dinosaur1 05-21-2012 10:28 AM
What paint scraper would be the best?
Fix'n it 05-21-2012 11:10 AM
try a razor scrapper.
dinosaur1 05-21-2012 11:47 AM
Tried that with no luck.
dinosaur1 05-21-2012 05:37 PM
Wouldn't paint stripper be my best option here?
