Discoloration Of Concrete From Plastic Sheet - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 08-13-2013, 01:08 AM   #1
Discoloration of concrete from plastic sheet
I'm curious as to how to prevent the discoloration of a concrete pad when using a plastic sheet or membrane to cure. Would it be reasonable to move the plastic every day or two so that the condensation is not concentrated in one area for the full cure time? It's possible that this question has already been asked, but I didn't know how to frame the search.
Cheers! Pete.
pdrewcock is offline   Reply With Quote
Old 08-13-2013, 06:55 AM   #2
DIY staff
Rewards Points: 7,174
I'm not a concrete guy---but around here we just spray the slab with water--some use a sprinkler---plastic is only used in the winter---
Old 08-13-2013, 10:27 AM   #3
Thanks oh'mike,
Since concrete should be kept from drying for at least 2 weeks (if possible 4), a sprinkler would have to run continuously or at least every 10 or so minutes. This is a lot of water and a chance of it not working. Also I understand that continuous watering could wash out the entrainment chemicals in the top layer leading to spalling. I don't know if this is fact.
Cheers! Pete.
Old 08-13-2013, 08:28 PM   #4
Rewards Points: 1,232
Jute or burlap under the poly is the only way to protect it. If water is cheap, you can make a sand dam around the perimeter and keep a sprinkler going.
The reality is that you do not need to hydrate a slab for a week, or 2 weeks, or 28 days. The curing of concrete is not linear it is exponential, so you really need to wet cure it for 2 or 3 days under the worst conditions.
If it is exterior in full sun and wind and will not be acid stained or dyed, buy a white pigmented cure and seal and be done with it.
Advice is free, Lessons begin at 75 bucks an hour.
Tscarborough is offline   Reply With Quote
The Following 2 Users Say Thank You to Tscarborough For This Useful Post:
concretemasonry (08-15-2013)
Old 08-14-2013, 08:39 AM   #5
Thanks Tscarborough,
There are so many different opinions out there. The burlap sounds like a good idea but fairly expensive since I don't know anyone to borrow it from. Flooding may be a workable alternative.
You say that concrete cures exponentially. What percent in the first day/second/third etc? Are ther charts at different temperatures that one can use? I ask because I have designed my slabs for minimum thickness and one is a carport that will be driven on.
Cheers! Pete.
Old 08-14-2013, 12:03 PM   #6
Concrete & Masonry
Rewards Points: 620
More than you'll ever want to know about curing concrete, and it's a reliable source as well:
http://www.cement.org/tech/cct_curing.asp
We've had this discussion here as recent as this Spring, and YES, plastic sheeting (Visqueen) will discolor concrete when left in direct contact for more than a very short time. Painter's dropclothes, bed sheets, etc... also work well between the concrete & plastic. My typical curing choice is spryed membrne though, as Tscar mentioned.........
jomama45 is offline   Reply With Quote
Old 08-14-2013, 12:32 PM   #7
Thanks jo,
Another interesting read. The chart is helpful and reconfirms the 28 day optimum for curing. I'll probably manage 14 days, but not being able to access my front door for 28 days might be pushing it. I won't be using a sprayed membrane since I may want to paint or stain the carport floor at some point.
Cheers! Pete.
Old 08-15-2013, 08:43 PM   #8
Rewards Points: 4,750
w/o studying the ' chart ' & respectfully to 'mama, you should easily be able to walk on the conc the next day - even the afternoon if its placed in the am,,, IF you're curing w/wtr spray, take off your shoes prior to entering the front door we paved 1/2mile of conc per day & had to saw/slice it into slabs,,, couldn't do that w/o walking on it
28d is only a time period for breaking to confirm strength,,, the fastest strength gain is the 1st 12hrs, then the 1st 24hrs ( steep curve ),,, typically strengths are ck'd in 24hrs, 7d, & 28d,,, after 7d we had const trks driving on it
IF the weather's extremely hot & windy, you might need to wtr 3d but i doubt it
Old 08-15-2013, 10:05 PM   #9
I wasn't concerned about walking on the concrete. My front door is four feet above the new slab and I will have to build a new entrance on the slab. I suppose I will be able to build on it after a few days. Just that trying to keep it wet and building on it becomes a. Bit of a trick. That's what I was referring to about not being able to access my entrance.
Anyway, an update: I have poured the slabs and covered with plastic. After the slabs were well set up, I was able to flood the top by misting under the plastic. The result was that the thin plastic sheet sucked down onto the slab with almost no wrinkles. It looks like a shiny new slab! I will continue to mist under the plastic if required. I will follow up with the results. Thanks to all for their input.
Cheers! Pete.
Old 09-12-2013, 09:51 AM   #10
An update:
It's been over a month now and the plastic is off. The slab looks great with no discoloration. I flooded under the plastic every day for two weeks and then left the plastic on without flooding for another two weeks. A little anal but the results are terrific.
The Following 2 Users Say Thank You to pdrewcock For This Useful Post:
Msradell (09-12-2013), oh'mike (09-12-2013)
How To Keep Your Concrete Mixer Driver Happy Mort How To Guides 38 02-12-2014 06:25 PM
Sheet of plastic for insulation?!? ARuby Insulation 0 02-17-2013 10:47 PM
Gravel crawl space. Plastic vs concrete howard.wheaton General DIY Discussions 14 12-04-2008 09:39 AM
Gravel crawl space. Plastic vs concrete howard.wheaton Remodeling 1 10-19-2008 12:12 AM
new concrete floor next to old concrete floor mattroos Building & Construction 10 08-28-2007 01:32 PM
