Diamond Grinding/polishing Pads? - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 02-05-2013, 04:03 PM   #1
diamond grinding/polishing pads?
can i find these at any local concrete shop or will i need to shop online,
Dantro is offline   Reply With Quote
Old 02-05-2013, 05:32 PM   #2
Rewards Points: 4,534
for the avg diy'er, ebay's a good place to begin,,, there's just too much of a learning curve to help you in a forum - diamond concentration & grit size are the most important parts,,, doubt seriously any conc co will stock these due to high cost of inventory, various rpm's needed to run the pads, & hp of the tool,,, usually begin w/metals then graduate to resins,,, wet or dry is another choice that's important,,, don't know of a diy-friendly place but you might start w/granQuartz,,, while this is a fairly expensive process, more importantly the skills aren't easy to acquire - good luck !
Old 02-05-2013, 07:07 PM   #3
I be found there hard to find locally. And as you said there is a lot of variables.
However working with natural stone, glass, and tile. I feel like I'm up for a challenge. I ll continue to do my research, and experiment. Always open to advice, thanks
Old 02-06-2013, 05:24 AM   #4
granite city tool ( barre, vt ) is another 1,,, they're mostly pro supply but will work w/you,,, also try http://www.egaonline.com/egamembers/ & pick out some supply houses
you have to remember they know what they're talking about & may have trouble understanding the language you use much like my bride, nagzille, when she tries to describe something to me we often don't speak the same language
Diamond shape towel ring? papageek Remodeling 4 08-06-2012 03:08 PM
changing brake pads on a 2001 Mercury sable with ABS deck hand Automotive Repairs 10 02-18-2010 03:57 AM
How to remove those sticky pads from the wall? darsunt Painting 5 10-08-2009 07:03 AM
Ipe deck boards on concrete pads duncan wood butcher Building & Construction 3 07-31-2008 09:59 AM
How to remove these 'pads'? Solvents? Mechanically? (Pads on mirror!) joeyboy General DIY Discussions 11 08-04-2007 07:01 PM
