Damp Concrete Floor - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 02-16-2012, 01:26 PM   #1
Damp concrete floor
My house, which is 2 years old, has a full basement that is poured concrete. I have been finishing the basement and I am now ready to do flooring. I had a flooring company come out and look and the floor and they tested it for moisture. The readings came back that the concrete was around 16% moisture which was very high. The floor and basement are both very dry. My house sits on the peak of a small hill and the sump pit hasn't ever had a drop of water in it and we have had several wet seasons. Several moths ago I had a radon system installed and when we drilled through the basement floor there was zero moisture under the slab. There isn't a vapor barrier under the slab though. The floor had a sealer applied to it after the pour. I have a dehumidifer running in the basement and it does not run very often and maintains a humidity of 40% very easily. I am very confused as to why my slab is so wet. Does anyone have any ideas as to why or how I can fix it? Thanks1
hardwick46 is offline   Reply With Quote
Old 02-16-2012, 01:37 PM   #2
Rewards Points: 13,300
Sounds like your doing all the right things.
Around here we have to have a vaper barrier and foam under the slab, to late now for you though.
May still be able to use an engineered flooring is you add a cork vaper barrier.
hardwick46 (02-16-2012)
Old 02-16-2012, 01:41 PM   #3
Thanks for the reply. Won't I have to worry about mold growing on the cork with the moisture coming out of my floor?
Old 02-16-2012, 03:31 PM   #4
Rewards Points: 636
it is why a vapor barrier is used due to thermal transfer causing moisture if i remember correctly same reason you use vapor barrier on insulated exterior walls i would look into "research" using a concrete sealing paint "like drylock" as a solution
jaydevries is offline   Reply With Quote
The Following User Says Thank You to jaydevries For This Useful Post:
hardwick46 (02-17-2012)
Old 02-16-2012, 06:27 PM   #5
Rewards Points: 626
All ground gives off moisture vapor I don't care if your in the dessert or in a rain forest the ground gives off moisture. When Cement is poured in a slab a real contractor that does not cut corners will lay down a 8-15 mil thick vapor barrier why? because concrete is porous and moisture vapor will migrate up and through the slab. Not much you can do now.
Nailbags is offline   Reply With Quote
The Following User Says Thank You to Nailbags For This Useful Post:
Old 02-16-2012, 06:33 PM   #6
Rewards Points: 626
a good link here http://www.concretenetwork.com/vapor-barriers/
Old 02-17-2012, 12:08 AM   #7
Registered User
Rewards Points: 5,216
You have a few choices, after the fact. Delta FL is one, or Fig. 2- just closed-cell foamboard, or Dricore, fig. 3: http://www.buildingscience.com/docum...ms?full_view=1
Photo 3, if you have the height (same as other, just more detail): http://www.buildingscience.com/docum...g-your-basment
Gary
The Following User Says Thank You to Gary in WA For This Useful Post:
Old 02-17-2012, 10:07 AM   #8
Those are great links. Thanks a lot for the info. My only problem with closed cell foamboard is that it usually requires a thermal barrier. Any way to get around that? I also looked into a product called Place N Go flooring that has dimpled underlayment covered with a piece of vinyl tile. Ceramic sounds like it
might be my best bet though.
Old 02-17-2012, 10:54 AM   #9
Rewards Points: 528
I would use
Dricore or tile.
framer52 is offline   Reply With Quote
The Following User Says Thank You to framer52 For This Useful Post:
hardwick46 (02-20-2012)
Old 02-20-2012, 08:41 AM   #10
If i use tile do I need to use any special kind of thinset for the concrete? Any special kind of grout? Thanks.
How does one repair small holes in a concrete floor? CnK of NY Flooring 3 07-23-2015 02:10 AM
Plywood sub floor over concrete slab targeted4u Flooring 9 07-10-2011 11:00 PM
Electrical Cable Run in Concrete Floor john curry Electrical 4 02-16-2010 05:54 PM
Concrete deck -- rotting floor joists jwill Building & Construction 6 09-05-2007 09:01 AM
new concrete floor next to old concrete floor mattroos Building & Construction 10 08-28-2007 02:32 PM
