Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 06-16-2012, 08:50 AM   #1
Damaged Curbside
Hello:
I need help figuring out how to repair a damaged part of the curbside in my driveway (see attached photo). It looks like the curbside mix originally contains small limestone (I could be wrong). I would like for the patch to blend-in if at all possible. Any thoughts?
Thanks in advance
Marc
aakhalifeh is offline   Reply With Quote
Old 06-16-2012, 09:17 AM   #2
Master General ReEngineer
Bondo's Avatar
Damaged Curbside
Ayuh,... Nothin you can do will stay put,...
But,...
You can fix it with type S mortar, 'n it might stay put for a little while...
Old 06-16-2012, 10:54 AM   #3
Damaged Curbside
cut that section out. and pour a new curb.
DIY'er, out of necessity. if i did this for a living, i would make about $3.50 an hour
i didn't make this world. i just live in it.
be careful of whom you make fun of. one day, that could be you...
Fix'n it is offline   Reply With Quote
Tags
concrete, curb, driveway
How do I remove part of the damaged subfloor? ChEMom Flooring 17 07-15-2011 01:28 PM
Replacing Termite Damaged Sill, Joists, and Girders bd_dc Building & Construction 0 02-02-2010 12:21 AM
Damaged fascia (Pics) timcsi Roofing 7 09-15-2009 11:00 AM
Replacing flood damaged furnace/ac cebeling HVAC 1 07-08-2009 08:35 PM
Damaged brick work Redders Building & Construction 1 04-02-2009 11:59 AM
