Cutting A Recess In Concrete Block Wall - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 08-28-2012, 01:10 PM   #1
cutting a recess in concrete block wall
My first post here. I would like to cut a recess in a concrete block wall along with channels to run audio wires for my surround sound system which will be placed in PVC trunking. Will an angle grinder with concrete blade be able to handle this task. The recess has to be wide enough to accommodate a tv mount. Thanks for any tips and info
Mroc13 is offline   Reply With Quote
Old 08-28-2012, 04:17 PM   #2
Rewards Points: 582
You can cut a groove out each side and knock out the middle with a hammer and chisel. Most electricians use chasing machines now though.
stuart45 is offline   Reply With Quote
Old 08-28-2012, 10:23 PM   #3
Thanks for the advice. The chasing machine looks to be very efficient but it much more expensive than my budget
Old 09-04-2012, 07:38 AM   #4
To the top
Wall - LOAD BEARING: How to Move? user49172 Building & Construction 4 04-04-2017 07:38 PM
Recess Outlet in Block wall Rze Electrical 8 02-08-2014 10:27 PM
Size Rebar Needed to Reinforce Bowed Block Wall frtools Concrete, Stone & Masonry 7 06-18-2012 11:28 AM
Bathroom Remo: Is this Plaster over Concrete Block? Mounting Backerboard over top? itcanadian Remodeling 10 03-21-2011 12:06 PM
Question on hanging new door in concrete block wall dave11 Carpentry 7 11-12-2009 07:21 PM
