Cutting Rebar To Fix Leak - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 05-02-2013, 08:35 PM   #1
Cutting rebar to fix leak
My super cut two 1/2" pieces of rebar and some smaller rebar to fix a leak. I'm curious whether it's acceptable (legally or otherwise) to build a building that requires cutting rebar in a case like this. I'm also wondering whether the rebar should be rejoined. I doubt the super has any intention of rejoining the rebar. The rebar was originally spaced at 2-1/2" centers and now it's 5".
Dorado is offline   Reply With Quote
Old 05-02-2013, 09:08 PM   #2
I should also add that he also replaced the pop-up tub stopper for the apartment above me and another section of pipe. I once asked him to fix mine and he says he can install a foot operated one but to replace it with a regular one with a lever he has to wait for the apartment under me to need a repair so he can cut a hole in their ceiling. The guy above me got lucky this time.
Old 05-02-2013, 09:19 PM   #3
I read a post on another forum by a contractor who had to fix a similar problem. He wrote "I came up with a detail to restore the capacity at the new opening in which the slab at the opening is chipped back to expose a min. of 8 inches of the existing slab steel. (It appears to be a two way slab with 5/8" bars @ 8" o/c e.w. bottom) Then a full-strength tension splice is made between the existing steel at each end with new bars using a flat plate and double flare groove welds." I have to decide whether to tell the super not to patch it on Monday because I'm thinking about reinforcing the rebar. Then I may have to talk to the building manager (it's a large co-op) about the building hiring someone.
Old 05-05-2013, 06:17 AM   #4
Rewards Points: 4,538
a DOT/FED accepted/approved method is chip back to sound conc, clean existing rebar, & splice in length of bar overlapped according to size ( length of o'lap = 10 x rebar diam - 3 ties ),,, conc repair is then made w/polymer-modified vertical/overhead patch material
we used this method/material on many hi-rise bldgs in the city + bdge work all over
Size Rebar Needed to Reinforce Bowed Block Wall frtools Concrete, Stone & Masonry 7 06-18-2012 12:28 PM
Possible small gas leak in black iron pipes WillK Plumbing 4 01-18-2012 12:07 AM
Vertical Rebar Layout in Block Wall Footing 99altrade Building & Construction 6 08-12-2011 10:32 PM
leak in cement tile roof virgo822 Roofing/Siding 2 07-23-2011 06:29 AM
Water Leak Detection AppleMac*Fit Plumbing 16 12-29-2008 07:30 AM
