Cutting Kitchen Slab - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 09-24-2012, 11:42 AM   #1
cutting kitchen slab
The wife (of course) wanted an island in the kitchen (the new kitchen)- So we are installing an island about 3' from the wall with a microwave in it.
I'm not sure how think the slab is- I tried to drill into - i got about an inch down and hit more resistance- drilling thru the first inch was pretty easy. there is also 1/2 plywood subfloor nailed to the top of the slab (don't ask me why - it's original form the 70's)- In any event the plywood might come in handy since I'm leaving it- My guess is I only need to "Channel" down about 1.5 inches to get a piece of conduit in there. I have a diamond tipped blade for my circ saw and that seemed to cut ok- I only need to cut out 3' long by about 2" wide channel. any other suggestions? yes- when I tested it - it's extremely dusty- but not sure if worth it to rent a larger saw- Should I use a Hilti?? (I used one in basement - but it was to enlarge a sump hole)- not to make a channel.. any advice is appreciated to make it work with less dust-
skinut2234 is offline   Reply With Quote
Old 09-25-2012, 11:57 AM   #2
anyone???
Old 09-26-2012, 01:23 AM   #3
Rewards Points: 152
If you have open access to the floor then a circular with a diamond should work fine. Have you wife stand there with a shop vac while you score 6-8 lines within the 2". Be sure to set you desired dept on the saw before cutting. Then use a chisel and hammer to do the rest. Should be a pretty easy job.
GL
TRUEPRO is offline   Reply With Quote
My new kitchen needs a facelift (oak cabinets have to stay) EclecticMom Interior Decorating 3 02-12-2012 09:45 PM
Kitchen Sink Moved - new kitchen sleepysmurf Plumbing 1 08-10-2010 06:38 AM
Replacement of flush mounted cutting board in kitchen counter top Humby Kitchen & Bath Remodeling 1 07-31-2010 02:45 PM
Cutting laminate kitchen cabinet blueturtle Carpentry 3 11-11-2009 01:37 PM
