Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 02-07-2012, 02:02 AM   #1
cutting into a brick wall to install a window..
So I've cut the tiles away in a central position in the downstairs kitchen.. There is an existing cavity wall behind the tile leading to the external brick wall.. The space for the window is directly through the double internal course of bricks supporting the main barer..!! As long as I put a lintel in can i get away with cutting the support course of bricks as well..??
kevco is offline   Reply With Quote
Old 02-07-2012, 07:06 AM   #2
Super Moderator
A picture from the inside and outside would help----Usually--yes---although cutting tends to be ugly--toothing in uncut bricks it the exposed edges is the proper way if the edges are exposed--
I'm not a mason--But I've had the work done several times and watched---
Garage brick wall repair TANME General Discussion 2 02-04-2010 07:19 AM
Question regarding adding a stud wall to a brick structure jcieutat Building & Construction 0 12-15-2009 08:41 PM
Cutting into foundation wall to install entry door. notenoughtime Building & Construction 7 08-19-2009 03:13 PM
Problem with window and everything around it malfunction Building & Construction 3 05-26-2009 06:11 PM
Window install question reguarding tyvek marlinpuppy Building & Construction 2 02-12-2009 12:56 PM
