Cutting Granite - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 12-09-2013, 12:54 PM   #1
Rewards Points: 256
I have an L shaped kitchen and would like budget granite.
I found 8' prefab slabs that will work, I just need to make a miter cut, and a sink cutout.
I have done enough tilework to know this will be a challenge.
I think I can get the sink cut fine as long as I dont do undermount.
Has anyone had success in making a granite miter joint look ok without prior experience/proper tools.
I was planning on using a saw guide and diamond blade in a circ saw while someone sprays with a spray bottle of water.
Granite shop quoted over 2k.
Stone for this project would cost me $400
Don't need a flawless unnoticeable seam, just cant be horrible either.
michaelcherr is offline   Reply With Quote
Old 12-09-2013, 06:13 PM   #2
Rewards Points: 4,638
think you're right - the sink cutout's the easy part,,, don't know how anyone could succeed w/o SOME experience & proper tools - even picking the right diamond blade is tricky - need to have correct rpm's ( surface feet per minute ), diamond shape/size/concentration, + the correct segment design,,, i suppose you could make a jig,,, its EXTREMELY important the water be applied at the right location as it does 2 things: 1, it keeps the blade cool; & 2, it flushes the swarf out of the cut
or you can just say f it - there's always jb weld good luck !
ps - keyword - ground fault circuit interrupter
Old 12-09-2013, 07:03 PM   #3
Rewards Points: 3,610
Your on the right track with the saw guide,but you'll need a lot more water than a spray bottle,figure on a hose to keep the blade cool and flush the swarf as IRC said,and the best blade to use would be a turbo with dampers on both sides of the blade,to lessen vibration of the blade,one like this.
http://www.homedepot.com/p/RIDGID-7-...6#.UqZmgE4o6po
Canarywood1 is offline   Reply With Quote
Old 12-09-2013, 07:05 PM   #4
Rewards Points: 256
Ha Jb weld.
I was planning on mixing the granite dust with clear epoxy to fix my issues.
I will probably beg granite shops to do the cutting, but i doubt they will.
Old 12-09-2013, 08:07 PM   #5
Rewards Points: 1,470
You DON'T want to do a miter cut.
A simple straight cut IS the way to go.
Make it nice and straight, level the pieces, then epoxy together (tint the epoxy. NOT with granite dust).
ktkelly is offline   Reply With Quote
Old 12-09-2013, 09:13 PM   #6
Rewards Points: 256
If my granite was a small radius or square edge, i wouldn't do a miter. There's no way to just do a 90deg butt joint when there's an oagee edge treatment.
Old 12-10-2013, 07:14 AM   #7
precision granite cutting depends on blade stability, rpm's, water in the right spot, diamond concentration/shape/size, & segment matrix,,, the ' aris ' often chips due to any of them not being correct,,, cutting pro's will even change blades depending on the granite itself as often 1 cuts differently than otghers.
we used akemi & granite dust for reprs
' ogee '
Old 12-10-2013, 09:18 AM   #8
I have never seen the joints done with granite dust. But it that's your thing, what the hey.
I understand about the OP's thoughts on doing a miter cut, since he has the pre-fab blanks. Good luck getting it just right. Wall run out can be a real b.....
Old 12-10-2013, 10:21 AM   #9
ooops, showing some age yep, today's installers use non-sag epoxies of various approx granite colors,,, the couple chips we found were reinforced/fill'd/extend'd w/granite dust to minimize repair shrinkage,,, it was something i had to show them otoh, they also had a vacuum thingie to draw both pieces together resulting in a much finer jnt we never had that !
Old 02-09-2014, 09:23 AM   #10
Rewards Points: 280
I am considering doing my own pre fab granite counters and would like to know how your project went?
This is how I see inside corners cut on granite. I suspect a long 45 would be difficult and fragile. Jim
jjrbus is offline   Reply With Quote
Old 02-09-2014, 10:05 AM   #11
both our corner's abut @ 90* as straight cuts,,, angle cutting introduces ' short-cutting ' because of blade circumference ( the top of the material's cut to your reference point BUT the bottom of the cut hasn't yet been completed,,, you'd need a vertical blade to properly due that finish cut,,, possibly 1 could eliminate short-cutting by over-cutting but i wouldn't / didn't
Old 02-09-2014, 10:07 AM   #12
JOATMON
ddawg16's Avatar
Rewards Points: 1,810
I'm the ultimate DIY'r....but that is one area that I would not do....
One mistake and that budget slab is now a budget couple pieces of rock.
If the professional makes a mistake....he replaces it.
How confident are you?
ddawg16 is online now   Reply With Quote
Old 02-09-2014, 03:30 PM   #13
Rewards Points: 280
Totally confident, darn the torpedoes, full speed ahead.
I have destroyed much more expensive material
Remember this is a DIY site, not a you better not try that you will only screw it up site! JIm
Old 02-10-2014, 09:05 AM   #14
Rewards Points: 256
Project update: I went with laminate. If only my source for $13/sq ft granite didn't have an ogee edge. . . .
Is this a lousy granite installation? timbo59 Kitchen & Bath Remodeling 70 05-16-2013 10:08 PM
Finding a good granite fabricator for kitchen countertop tseverson Kitchen & Bath Remodeling 5 04-20-2012 02:50 AM
cutting granite myself denemante Remodeling 6 05-13-2011 12:04 AM
Cutting Granite indep General DIY Discussions 5 04-09-2011 10:54 AM
Stonemark & Silestone Countertops......??? DepotDweller Remodeling 9 06-25-2009 11:44 AM
