Cutting Concrete Slab For Trench Drain - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 03-27-2012, 10:47 AM   #1
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,262
Cutting concrete slab for trench drain
I need to install a trench drain in front of my garage door. Need to cut a slot 5" wide by approx 18' long in the 4" concrete slab (20+ year old concrete if it matters). What is the best way? What machine should I look for at the rental center? Or would I be better off to hire a concrete specialty company?
After the cuts are made, bust it up with a sledge to remove?
Coastal South Carolina
Old 03-27-2012, 10:57 AM   #2
Civil Engineer
Rewards Points: 4,942
I would rent a concrete saw with a diamond blade on a track. It will make perfect cuts. Typically these are gas powered saws, they may come equipped with a water drip system to keep down the dust. If you use it, make sure you wear a NIOSH approved mask, as the dust is extremely harmful if you get it in your lungs.
Old 03-27-2012, 07:06 PM   #3
Concrete & Masonry
Rewards Points: 636
Do you have a picture or link of what the track looks like, because I've never seen one, other than on wall saws...... Certainly not available at a rental store here, but it could be an intersting set-up ot see.
rjniles,
If you're only going to saw out 5", how will you seal the drain up to each side of the slab?
As for the cutting, I'd use a hand held saw if you have the strenght (& back) to support it. Fairly easy to rent, and relatively cheap. Alos, with a handheld, you can hold the saw on the slightest of angles to create a beveled cut-out that will not bind when you remove it. Think of a very slight "V", where the gap gets wider as you pull the pieces upward........
jomama45 is offline   Reply With Quote
Old 03-28-2012, 07:53 AM   #4
A "Handy Husband"
rjniles's Avatar
Thanks for the feedback.
The drain is 4.75" wide, I plan to use a concrete grout to seal it in the cut concrete.
Removing basement tile and pouring concrete slab tondar Building & Construction 12 11-05-2010 11:28 AM
Pouring Concrete Slab in a small rickety garage. RORO Building & Construction 0 10-19-2010 03:56 PM
Drain pipes in slab acerunner Plumbing 0 10-04-2010 12:24 PM
Adding exterior drain with concrete steps in way steveel Building & Construction 5 09-10-2010 04:23 PM
Concrete slab weeps moisture dale h Flooring 2 04-30-2005 10:29 AM
