-   Concrete, Stone & Masonry (http://www.diychatroom.com/f105/)
-   -   Cutting concrete slab for trench drain (http://www.diychatroom.com/f105/cutting-concrete-slab-trench-drain-138433/)
rjniles 03-27-2012 11:47 AM
I need to install a trench drain in front of my garage door. Need to cut a slot 5" wide by approx 18' long in the 4" concrete slab (20+ year old concrete if it matters). What is the best way? What machine should I look for at the rental center? Or would I be better off to hire a concrete specialty company?
After the cuts are made, bust it up with a sledge to remove?
Daniel Holzman 03-27-2012 11:57 AM
I would rent a concrete saw with a diamond blade on a track. It will make perfect cuts. Typically these are gas powered saws, they may come equipped with a water drip system to keep down the dust. If you use it, make sure you wear a NIOSH approved mask, as the dust is extremely harmful if you get it in your lungs.
jomama45 03-27-2012 08:06 PM
Do you have a picture or link of what the track looks like, because I've never seen one, other than on wall saws...... Certainly not available at a rental store here, but it could be an intersting set-up ot see.
rjniles,
If you're only going to saw out 5", how will you seal the drain up to each side of the slab?
As for the cutting, I'd use a hand held saw if you have the strenght (& back) to support it. Fairly easy to rent, and relatively cheap. Alos, with a handheld, you can hold the saw on the slightest of angles to create a beveled cut-out that will not bind when you remove it. Think of a very slight "V", where the gap gets wider as you pull the pieces upward........
rjniles 03-28-2012 08:53 AM
Thanks for the feedback.
http://www.mcnichols.com/resources/products/tdkit.gif
The drain is 4.75" wide, I plan to use a concrete grout to seal it in the cut concrete.
