Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 10-27-2012, 02:29 PM   #1
Cutting concrete foundations
how do contractors cut concete foundations to install a egress window in a beasement
Rachel58 is offline   Reply With Quote
Old 10-27-2012, 02:50 PM   #2
http://www.homedepotrents.com/proToo..._-concrete_saw
There's also a chain saw made just for this.
Old 10-27-2012, 05:39 PM   #3
GBrackins's Avatar
call up some foundation companies and builders and ask who do they use to cut concrete. it is usually best to hire that out since they have the equipment and more importantly the know how ..... someone experienced can make it look simple to do
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old 10-28-2012, 03:16 PM   #4
Concrete & Masonry
We start with a standard diamond blade in a 14" gas cut-off saw, step the blade up to a "fat blade" to compensate for teh wide chain width, and then to a wet-cut chainsaw to finish the cut off. The chainsaw allows you to cut square corners w/o overcutting, keep nice straight cuts/jambs, and keep most of the mess/fumes on the exterior.
Some companies also use wall mounted as well.
jomama45 is offline   Reply With Quote
Concrete Basics for the DIYer Mort Concrete, Stone & Masonry 7 11-22-2012 12:19 PM
Need of some help with concrete driveway & patio? imola ghost Concrete, Stone & Masonry 25 04-05-2012 10:03 AM
Creating a flat floor on an angled concrete floor? Magno Building & Construction 1 04-14-2011 06:42 AM
Cutting Concrete Floor sdlehman Building & Construction 8 09-30-2009 05:17 PM
Cutting Concrete Slab for New Door MikeinBurien Remodeling 9 05-10-2007 05:53 AM
