Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 10-01-2012, 06:58 PM   #1
Cutting concrete expansion joints
What type of blade should I use to cut expansion joints in already hard cured sidewalk? I've tried 2 types that didn't work.
Skill-saw or angle grinder?
Depth?
Wet it dry?
Phuffman is offline   Reply With Quote
Old 10-01-2012, 07:19 PM   #2
Concrete & Masonry
Diamond blade.
Either a Skil-saw or grinder will work.
Dry is easier.
Cut them as soon as possible, stop and wait if there's severe unraveling (chipping).
jomama45 is offline   Reply With Quote
Old 10-01-2012, 07:33 PM   #3
Depth?
Wet it dry?
Diamond blade for sure, depth is 1/4 of the thickness,how many running feet do you have to do??
Canarywood1 is offline   Reply With Quote
Old 10-01-2012, 07:39 PM   #4
Civil Engineer
When cutting concrete with a diamond blade, be sure to wear a NIOSH approved mask, as concrete dust is extremely bad for your lungs, and you are going to generate a lot of dust during the cut. Use of water reduces but does not eliminate the dust.
Old 10-01-2012, 10:44 PM   #5
I've got 3 separate cuts at 3' per cut. Not much to do, really, but frustrating that I can't get a blade to work out right and just cut.
Old 10-01-2012, 11:34 PM   #6
Depth?
Wet it dry?
for your information: http://www.youtube.com/watch?v=_PZx9...eature=related
epson is offline   Reply With Quote
Linoleum on concrete expansion gap question toobhed Flooring 0 03-13-2012 04:15 PM
Filling/covering control joints while laying tile on concrete Marita Tiling, ceramics, marble 0 09-19-2010 02:46 PM
Cutting a hole in concrete wall upinsmoke Building & Construction 4 03-07-2010 10:20 AM
Concrete - Control Joints AndrewF Building & Construction 10 08-09-2009 03:42 PM
Concrete patio w/o expansion joints TrentJA Building & Construction 7 07-24-2009 04:28 PM
