Cut/trim Concrete - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 08-21-2015, 12:02 PM   #1
Rewards Points: 14
Cut/trim concrete
I just got a Ryobi AG 4531G angle grinder and some 4 1/2 masonry cut off discs. When I opened the angle grinder up, it says to use only Type 27 depressed center wheels (recessed, or indented hubs) that fit into the recessed part of the arbor or spindle on the machine. "Never attach a Type 1 sraight or cut-off wheel..."
Is this setup unique to Ryobi, or are they all like that?
I have a 7 1/2 inch circular saw I've been using to cut concrete (a very sloppy foundation job that a local contractor did), but need to get into some tight corners that I thought an angle grinder would do.
Will this not work? I'm ready to return the angle grinder if I can't use it for this.
Yod12 is offline   Reply With Quote
Old 08-21-2015, 01:54 PM   #2
Rewards Points: 4,584
if you're cutting conc, use diamond blades (ebay - $4 ea),,, we use 4" grinders all the time w/diamond blades - NEVER masonry blades,,, UNLESS you can use a hot press blade (edmar), all the others are a waste
Concrete shower floor and drain issue whoowl Kitchen & Bath Remodeling 0 07-24-2015 04:10 AM
How to Calculate Store Bought Concrete Coverage by Bag Size Willie T How To Guides 9 11-29-2011 12:32 PM
Laminate Flooring on Two Different Concrete Heights mrken Flooring 4 12-14-2010 01:56 PM
New Concrete Walkway along side of house braverichard Building & Construction 0 11-03-2010 11:12 AM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 09:49 AM
