Cut CMU On The Long Dimension - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 11-26-2012, 11:48 AM   #1
Rewards Points: 121
Cut CMU on the long dimension
I have found a lot of articles on cutting a CMU cross wise but not the long direction. Any advise would be welcome on the correct procedure and tools.
Thanks.
jrepp44 is offline   Reply With Quote
Old 11-26-2012, 02:51 PM   #2
Rewards Points: 1,232
It takes a 20" saw to cut through in one pass. What are you trying to do?
Advice is free, Lessons begin at 75 bucks an hour.
Tscarborough is offline   Reply With Quote
Old 11-26-2012, 03:29 PM   #3
Rewards Points: 121
I want to cut the CUM in half the long way - don't necessarily need to do it in one pass.
Old 11-26-2012, 04:56 PM   #4
Rewards Points: 4,656
aren't 4" grinders & diamond blades wonderful ?
Old 11-26-2012, 04:58 PM   #5
cheif outhouse engineer
You can put a 7 1/4" diamond blade in a skil saw and cut both sides leaving a small connection in the middle that will break by simply tapping the block.
Very dusty, and it will burn up your saw eventually, but it does work.
dakzaag is offline   Reply With Quote
Old 11-26-2012, 08:02 PM   #6
Concrete & Masonry
Rewards Points: 580
I'm not trying to sound smart, but if you have a lot of them, why not just buy the correct width right away? The reason I ask is because we can get a multitude of width, all readily available here 1", 1 5/8", 2 5/8", 3 5/8", 4 5/8", etc.....
jomama45 is offline   Reply With Quote
Old 11-26-2012, 08:27 PM   #7
Yeah, just buy 4x8x16 CMU and be done with it.
Old 11-27-2012, 09:13 AM   #8
Rewards Points: 121
Thanks - Never knew odd sizes existed (too much relying on the big box stores) - called a local masonry supplier (Acme Brick) - they have them in stock
Old 11-27-2012, 01:46 PM   #9
Rewards Points: 502
But we still don't know why you want to cut them in half!
tony.g is offline   Reply With Quote
Old 11-28-2012, 08:44 AM   #10
Rewards Points: 121
I am building a new CMU column that needs to be the same height as an existing wall, if I use a full height CMU for the top row the new column will be 4" to high.
The Following User Says Thank You to jrepp44 For This Useful Post:
tony.g (11-28-2012)
Old 11-28-2012, 09:00 AM   #11
Then you do not want a 4x8x16, you want an 8x4x16 half-hi.
The Following User Says Thank You to Tscarborough For This Useful Post:
jrepp44 (11-28-2012)
Old 11-29-2012, 10:37 PM   #12
Concrete & Masonry
Rewards Points: 580
Is it an 8" half course solid, or a 4" solid???????
Old 11-30-2012, 04:52 AM   #13
the world has certainly changed, hasn't it ?
Long Handled weeder Ultrarunner2017 Landscaping & Lawn Care 0 06-24-2010 06:10 PM
How long between tiling steps? ptraz Flooring 4 03-12-2010 07:13 PM
How long does it take for Aura to cure? slickracer Painting 8 01-03-2010 04:58 PM
Why long lasting bulbs go out of service quickly? art2670 Electrical 8 10-27-2009 08:10 AM
Long range HVAC planning. dalesd HVAC 2 02-23-2006 12:37 PM
