-   Concrete, Stone & Masonry (http://www.diychatroom.com/f105/)
-   -   Cut CMU on the long dimension (http://www.diychatroom.com/f105/cut-cmu-long-dimension-164772/)
jrepp44 11-26-2012 12:48 PM
I have found a lot of articles on cutting a CMU cross wise but not the long direction. Any advise would be welcome on the correct procedure and tools.
Thanks.
Tscarborough 11-26-2012 03:51 PM
It takes a 20" saw to cut through in one pass. What are you trying to do?
jrepp44 11-26-2012 04:29 PM
I want to cut the CUM in half the long way - don't necessarily need to do it in one pass.
stadry 11-26-2012 05:56 PM
aren't 4" grinders & diamond blades wonderful ?
dakzaag 11-26-2012 05:58 PM
You can put a 7 1/4" diamond blade in a skil saw and cut both sides leaving a small connection in the middle that will break by simply tapping the block.
Very dusty, and it will burn up your saw eventually, but it does work.
jomama45 11-26-2012 09:02 PM
I'm not trying to sound smart, but if you have a lot of them, why not just buy the correct width right away? The reason I ask is because we can get a multitude of width, all readily available here 1", 1 5/8", 2 5/8", 3 5/8", 4 5/8", etc.....
Tscarborough 11-26-2012 09:27 PM
Yeah, just buy 4x8x16 CMU and be done with it.
jrepp44 11-27-2012 10:13 AM
Thanks - Never knew odd sizes existed (too much relying on the big box stores) - called a local masonry supplier (Acme Brick) - they have them in stock :)
tony.g 11-27-2012 02:46 PM
But we still don't know why you want to cut them in half!
jrepp44 11-28-2012 09:44 AM
I am building a new CMU column that needs to be the same height as an existing wall, if I use a full height CMU for the top row the new column will be 4" to high.
Tscarborough 11-28-2012 10:00 AM
Then you do not want a 4x8x16, you want an 8x4x16 half-hi.
jomama45 11-29-2012 11:37 PM
Is it an 8" half course solid, or a 4" solid??????? :laughing::laughing:
stadry 11-30-2012 05:52 AM
the world has certainly changed, hasn't it ? :huh:
