Cure Time Before Fastening - Concrete, Stone & Masonry - Page 2 - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 05-14-2013, 02:16 PM   #16
Rewards Points: 518
They are 22ft long 9ft high sheeted. Even with four people its not easy to grip and lift. Not sure how long yours were.
n0c7 is offline   Reply With Quote
Old 05-15-2013, 12:06 AM   #17
World's Tallest Midget
Mort's Avatar
Rewards Points: 690
Originally Posted by Willie T
See? This is one of many reasons I don't suggest getting on a slab prior to at least a week passing. You never know WHAT the questioner has in mind doing. While anchor bolts should have already been installed in the concrete, this is not the case... and none of us knew that.
That's what I get for skimming. :-D
I hate signatures.
Mort is offline   Reply With Quote
Old 05-15-2013, 10:25 AM   #18
Old School
Willie T's Avatar
Originally Posted by n0c7 View Post
Anchor bolts suck to lift large walls presheeted on top of. Best hold though.
I'm trusting this is just a "comment", and not your true attitude about constructing a dwelling your family is going to be sleeping in.
We often build two-story homes with multiple continuously connected rods of all-thread running all the way from down inside the foundation concrete, up through the top plates of the second floor.
Willie T
Old 05-15-2013, 10:28 AM   #19
Rewards Points: 626
I just had a 6 inch curb added to my garage pad. I'm going to be fastening the walls with ramset nails. How long should I wait for the concrete to cure before adding weight and fastening?
How come you did not use anchor bolts, is my question? Instead of using ram set nails I would be drilling and epoxing the proper anchor bolts in and laying a sill plate down.
Nailbags is offline   Reply With Quote
Old 05-15-2013, 10:38 AM   #20
Rewards Points: 518
How long do I have I wait before nailing or drilling into fresh concrete?
Old 05-15-2013, 11:22 PM   #21
Msradell's Avatar
Rewards Points: 84
That's just because you have those pesky hurricanes down there! In the real world, I've never seen or heard of anything like that being done.
Msradell is offline   Reply With Quote
Old 05-16-2013, 01:51 PM   #22
Rewards Points: 3,344
Easier drilling when it's green,you can drill now,i wouldn't be using a ramset near the edge or ends yet.
Canarywood1 is offline   Reply With Quote
Old 05-16-2013, 02:17 PM   #23
Rewards Points: 518
If drilling while green can you still use wedge anchors?
Old 05-16-2013, 04:32 PM   #24
Rewards Points: 37
If you poured on Mon 5-13-13 it okay to put wedge quick bolts in now. I would use 1/2" bolts rated for treated wood & real hammer drill & bit not some lightweight pc. of junk. Code here will not allow you to powder activated nails to secure exterior walls. When we build garages we always use quick bolts instead of putting in anchors bolts. Pour the 1st day frame the 2nd day.
TOOL82 is offline   Reply With Quote
Problems, GE SunSmart Digital Timer 15312 Mike Muls Electrical 41 07-30-2016 09:13 PM
Cure Time For Spar Urathane rjordan393 Painting 5 02-08-2012 06:16 AM
Low budget concrete patio, sections at a time... vertigoelectric Flooring 0 01-29-2012 05:13 PM
Fastening Azek Trim joetab24 Building & Construction 13 08-15-2011 07:23 PM
wait time from first thinset coat to redguard app 4just1don Building & Construction 3 08-06-2011 06:09 AM
