Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 03-12-2013, 12:54 PM   #1
Cultured Stone Project
Hi everyone, I need a little advice from the experts. I need to make my brick fireplace opening wider to allow my bifold glass doors to open. The fireplace sits 4 inches back in the opening. When I install the cultured stone around the opening it makes it 2 inches smaller on each side because of the thickness of the stone. My idea was to remove 2 inches of brick on each side. The steel lental runs past far enough to still support the brick above but I will still support with 2X4's until the brick is installed. I will drill holes along a line and hope i can chip the brick out. Using a angle grinder or saw is way to dusty,if you have any other ideas I would greatly appreciate it. Sorry about the long post. Thank You
specs2020 is offline   Reply With Quote
Old 03-13-2013, 11:36 AM   #2
Here are some pictures of the problem i am having. Hope someone can help.
Old 03-14-2013, 06:26 PM   #3
Concrete & Masonry
Not sure how well drilling those holes will work, you may end up loosing the half brick on every other course. I'd be more inclined to use a grinder with a vacuum attached/close by, along with the biggest fan you can find pushing air up the chimney. Or, plastic that area in from the floor to ceiling.
I'd also consider taking at least 2" out of the brick, as you'll have mortar behind the stone as well, and there's likely at least an inch or 2 of black metal hidden........
jomama45 is offline   Reply With Quote
Old 03-14-2013, 07:01 PM   #4
Order smaller doors.
Old 03-14-2013, 10:26 PM   #5
Concrete & Masonry
Oh boy..........................
Old 03-17-2013, 09:27 AM   #6
I was hoping that I would not have to cut brick out but it looks like that is my only alternative. Smaller doors are not an option. It looks like I better start cutting or drilling. Thanks for the help.
Old 03-18-2013, 01:05 PM   #7
Problem solved. All I did was cut back on a 45 degree angle on the ends of the stone and that lets the doors open almost completly. I thought I would post this solution for anybody that may have the same problem.
Old 03-19-2013, 09:33 PM   #8
Concrete & Masonry
Dind't that expose the aggregate inside of the stone though? Maybe I'm not envisioning what you're describing correctly??
Old 03-20-2013, 11:24 AM   #9
Yes it did but with the greys and brown color of the stone I should be able to wipe some mortar or color grout on the ends. The masons who came to give an estimate for the job told my wife they would have to cut the cultured stones back at an angle so the doors could open.I was not their when they came but I doubt that cutting out brick would be an option with them.
Sealing cultured stone valcarmo72 Concrete, Stone & Masonry 8 02-20-2013 06:41 PM
Cultured Stone fireplace lindyloo Concrete, Stone & Masonry 3 10-31-2012 05:32 PM
cultured stone over real stone sulevia Building & Construction 3 09-23-2010 12:23 AM
what tool to rent to remove cultured stone tgseaver Tools 4 09-07-2009 09:09 PM
J-Weep / Flashing for exterior cultured stone veneer wall. Spud Building & Construction 18 08-31-2009 10:44 PM
