Cultured Stone Over Vinyl Siding - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 03-14-2012, 09:26 AM   #1
Cultured stone over vinyl siding
I am removing my vinyl cedar shake siding and wanting to install cultured stone on the exterior of my home. I am repairing a leak and want to replace the siding with stone. Please advise with any suggestions. I currently have sheathing with Tyvek over the top.
skates401 is offline   Reply With Quote
Old 03-14-2012, 09:36 AM   #2
Rewards Points: 14,010
I'd be consulting the install info with the manufacturer of the faux stone, not counting on advice posted here that could come from anybody on the planet.
Old 03-14-2012, 05:52 PM   #3
Chicago, IL
Michael Thomas's Avatar
Take a look here: http://blog.wahigroup.com/files/4/3/...article_1_.pdf
Home Inspections, Infrared (Thermal Imaging) Leak Identification and Inspection Services, Roof, Attic, Building, Basement and Foundation Moisture Intrusion and Water Leak Inspections, Troubled Building Consultations - Serving Chicago and Suburbs http://paragoninspects.com/
Michael Thomas is offline   Reply With Quote
Old 03-14-2012, 06:22 PM   #4
Rewards Points: 4,748
expect to use expanded wire mesh properly attached to the wall,,, you may also need to attach the stone mechanically & might even need a brick ledge, too,,, we often do that on our planet :-)
Vinyl Siding Help Needed swiederin Building & Construction 4 10-24-2011 09:02 PM
Insurance claim for vinyl siding thru-hiker Off Topic 3 12-02-2010 02:29 PM
foam back siding vs. reg vinyl siding marnic Building & Construction 3 02-16-2009 07:48 AM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 12:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 03:35 PM
