Crumbling Concrete Steps - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 03-20-2012, 10:06 AM   #1
RetiredSoldier's Avatar
Rewards Points: 27
Crumbling concrete steps
I would like anyone's suggestions for repairing this mess.
I've been thinking of just replacing the top step. However I'm afraid that may just be a temp repair and I'll find myself fixing it soon after. We have bad winters and I need to consider the heaving issues. Any thoughts?
RetiredSoldier is offline   Reply With Quote
Old 03-20-2012, 07:50 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 628
Ayuh,.... It appears the top step is an after thought, poured separately...
Knockin' it outa there, 'n pourin' a new monolithic pour would last a long time...
After, ya dig out Under that top pour, 'n stabilize it's base.... That's where the failure is....
Throw some steel in it, 'n yer grandchildren will grow old walkin' up it...
Old 03-20-2012, 11:15 PM   #3
Rewards Points: 940
I don't know what the surrounding area looks like, but I'd like to see you use 3 big slabs of stone in there.
Excavate, compact in a stone base.
Set first slab, fill any loose area with base.
Repeat as necessary.
As far as the area on the right, I would try to stack some rocks there to keep the grade back.
cleveman is offline   Reply With Quote
Old 03-21-2012, 06:59 PM   #4
Rewards Points: 27
Thank you for your suggestions. I didn't even think of individual slabs.
Old 03-21-2012, 07:48 PM   #5
Too Short? Cut it Again!
Get rid of the dead stuff. Then use something like this.
http://www.abatron.com/buildingandre....html?vmcchk=1
Adhering Wood steps to Concrete LouiseR36 Building & Construction 11 08-12-2010 05:39 PM
fixing concrete steps with slate jarby Building & Construction 3 06-04-2010 09:20 AM
Rebuild concrete steps leading to basement gruntman Building & Construction 32 09-30-2009 12:55 PM
forms for semi-circular concrete steps cirsteps Building & Construction 7 10-23-2008 12:22 AM
deck header over concrete steps and other deck questions bobcatnj Building & Construction 6 05-09-2008 03:54 PM
