Cracks In Newly Poured Slab - Concrete, Stone & Masonry - Page 2 - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 07-13-2012, 03:55 PM   #16
concretemasonry's Avatar
Rewards Points: 2,654
The problem is with a slab and not a retaining wall.
Too much water in the mix (high slump ordered) or water added to make placement easier will reduce the concrete strength and make placement easier with the result of excess water on the surface and the lower concrete to settle and pull away from the bars and cause cracks, shrinkage and and lower durability. Big slabs have a problem of overcoming the labor and experience available, especially with higher air temperatures.
Dick
concretemasonry is online now   Reply With Quote
Old 07-13-2012, 04:49 PM   #17
Originally Posted by GBrackins View Post
did you use a mechanical vibrator on the retaining wall pour?
i used the vibrator in slab yes....those pics are of my ground floor slab...not retaining wall.
charmer786@ is offline   Reply With Quote
Old 07-13-2012, 04:55 PM   #18
Originally Posted by Canarywood1 View Post
No that's not what I thought it was,but those pics are pretty close up,any chance you can post pics so we can see the slab from a normal distance??
okay,its difficult but i will try.
but as you guys have got the idea now....other guy says its look like plastic shrinkage...and he has given the link for this...i saw the picture on that link and it was almost the same crack which i have developed in my slab....so i think its plastic shrinkage.
what you guys suggest?...continue my construction or should take care of these cracks if they are realy a problem?
Old 07-18-2012, 03:10 PM   #19
tell me how long should i cure (with water) this slab?
Old 07-18-2012, 04:03 PM   #20
GBrackins's Avatar
Rewards Points: 2,108
No I was asking because you mentioned honeycomb in the retaining wall. It has been my experience that honeycomb is caused by air pockets/voids in the concrete.
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old 07-18-2012, 05:13 PM   #21
World's Tallest Midget
Mort's Avatar
Rewards Points: 694
NRMCA says they aren't a problem, and shouldn't impair the structure, so unless you hate the look, I'd leave them. Usually you wet cure for 7 days. But if this is plastic shrinkage, it sounds like we were right in that it was too hot and the placement took too long.
Mort is online now   Reply With Quote
Pouring Patio Slab and Post Footings Question average_male Building & Construction 22 04-04-2016 12:13 PM
crawlspace slab voids, basement water geoffmiller Building & Construction 0 11-25-2011 09:01 AM
Need Help Fixing Damp Slab Problem in Shop OlyTDI Building & Construction 10 10-30-2011 12:35 AM
Cold water is warm - hot water leak under slab? Homerepairguy Plumbing 9 10-13-2010 08:17 PM
Need Help??? Newly poured concrete around pool is too rough! Ms TAB Building & Construction 6 09-25-2010 01:42 AM
