Cracks In Newly Poured Slab - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 07-11-2012, 02:58 PM   #1
cracks in newly poured slab
i recently poured a 8'' thick slab of my new home....the ratio was 1:2:2 designed by my engineer....the temperature was around 33 degree...it was a hot day though. the concrete started at 8 am and ended 5 pm.
however, i noticed cracks in different areas of the slab...people told me that this is no issue...but i still feel afraid of the cracks......is this really a non issue thing?....help would be appreciated
charmer786@ is offline   Reply With Quote
Old 07-11-2012, 06:07 PM   #2
Rewards Points: 2,212
What size of cracks?
Hairline cracks are probably no big issue
mae-ling is offline   Reply With Quote
Old 07-11-2012, 06:27 PM   #3
GBrackins's Avatar
Rewards Points: 2,108
all concrete cracks ..... the extend and size of the cracks is what is important.
According to the Section 2-2-4 of the 4th edition of the "Residential Construction Performance Guidelines for Professional Builders and Remodelers" as published by the National Association of Home Builders (NAHB), "Minor cracks in concrete floor slabs are normal. Cracks exceeding 3/16" in width or 3/16" in vertical displacement are a concern and should be repaired if the slab is in conditioned space or the crack interferes within the installation of finish flooring."
Hope this helps. Good Luck!
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old 07-11-2012, 06:52 PM   #4
Rewards Points: 3,630
Don't know where your located,but those temps are pretty cold for this time of year,what was the condition of your grade when the pour was started,how many yards were poured,how was the concrete protected after the pour was completed,and why did it take so long to complete the pour?
Canarywood1 is offline   Reply With Quote
Old 07-11-2012, 08:09 PM   #5
World's Tallest Midget
Mort's Avatar
Rewards Points: 692
I'm guessing he's Canadian, so that would be Celsius, which is pretty warm.
If it took that long, I would say there's probably a cold joint in there somewhere. How big is the slab, and are there control joints in it? Concrete is going to crack, it is a fact of life. The control joints just tell it where to crack.
Mort is online now   Reply With Quote
Old 07-12-2012, 05:17 PM   #6
the weather was pretty warm. the concrete took that long because we poured it with mixture machine...the total area was 400 square yards.
those cracks are like boxes in shape..looke like as they are on steel....i mean...not long and straight cracks..but not that much wide...a matchstick cannot enter in it.
however,my engineer told me that i used lots of water in it in hot weather...thats why those cracks shown up...but that is not an issue.
Old 07-12-2012, 06:30 PM   #7
concretemasonry's Avatar
Rewards Points: 2,608
Since there was little information supplied, I assume the location referred to degrees C since 33 F would not exist for recent periods.
A slab of unknown size and 8" thick that took than long to place and finish was probably a locally site mixed concrete (instead of ready-mix) based on individual batch proportions of variable quality/properties and subjected to unknown curing conditions, it is not surprising there are some cracks showing in a short period of time after finishing/placement.
Based on the information, I assume the cracks seen are due to curing problems dues to temperatures and unknown curing are superficial and hopefully, there will not be other more severe to the structure. hopefully, it will not develop into more severe problems for the entire foundation of a costly home.
The excess of water will ultimately result in lower strengths and more cracks in the future.
Dick
concretemasonry is offline   Reply With Quote
Old 07-12-2012, 07:11 PM   #8
"those cracks are like boxes in shape..looke like as they are on steel."
Sounds like bleed water dried on the surface,not a problem because it will br covered.
Just curious as to why you mixed that large an amount of concrete,rather than use redi-mix,had to be around 88-90 yards,and did you use bag cement??
Old 07-12-2012, 09:02 PM   #9
Mort's Avatar
Rewards Points: 692
I got 44.4 yards, and that is entirely too much to mix by hand and expect a good result. That's readymix trucks, I can't imagine loading all those bags into a mixer.
Old 07-13-2012, 04:38 AM   #10
i have had an bad experience with ready mix....i poured my retaining wall and got lots of honey comb .
however, i m posting pictures of the cracks ..they would not tell you the exact size and idea ..but it will be a big help though.....have a look at them please.
Old 07-13-2012, 04:54 AM   #11
Shot at 2012-07-13
Shot at 2012-07-13
Shot at 2012-07-13
Shot at 2012-07-13
Old 07-13-2012, 05:25 AM   #12
note. these pictures are from different area of slab. and only from surface level. its been three days now since we poured the slab.
Old 07-13-2012, 11:49 AM   #13
GBrackins's Avatar
did you use a mechanical vibrator on the retaining wall pour?
Gary
Old 07-13-2012, 03:02 PM   #14
No that's not what I thought it was,but those pics are pretty close up,any chance you can post pics so we can see the slab from a normal distance??
Old 07-13-2012, 03:50 PM   #15
Concrete & Masonry
Rewards Points: 582
Looks like plastic shrinkage cracking to me........
http://nrmca.org/aboutconcrete/cips/05p.pdf
jomama45 is offline   Reply With Quote
Pouring Patio Slab and Post Footings Question average_male Building & Construction 22 04-04-2016 12:13 PM
crawlspace slab voids, basement water geoffmiller Building & Construction 0 11-25-2011 09:01 AM
Need Help Fixing Damp Slab Problem in Shop OlyTDI Building & Construction 10 10-30-2011 12:35 AM
Cold water is warm - hot water leak under slab? Homerepairguy Plumbing 9 10-13-2010 08:17 PM
Need Help??? Newly poured concrete around pool is too rough! Ms TAB Building & Construction 6 09-25-2010 01:42 AM
