Cracks In New Concrete - Concrete, Stone & Masonry - Page 2 - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 09-17-2013, 04:58 PM   #16
Concrete & Masonry
Rewards Points: 568
You need to answer a few questions before you get any useful answers IMO.
First, where are you located?? Maybe I missed it, but in many areas, I'd doubt a micro topping would last very long on such poor concrete.
Second, do you have a contract at all, and does it have any specifications to concrete design strength, thickess, etc... at all?
Third, why is the concrete supplier working directly with you if the contractor is their customer??
jomama45 is offline   Reply With Quote
Old 09-18-2013, 05:25 AM   #17
Rewards Points: 4,642
as generally defined, ' microtopping ' has no aggregate therefore its unsuitable for exterior use - its just polymer, water, & ceement.
IF your compressive strength's that low, placing a 4.5 - 4.5K comp strength o'lay's pointless,,, t-scar said it best = replace it ( by someone who knows this time ! )
Old 09-18-2013, 09:17 PM   #18
Msradell's Avatar
Rewards Points: 210
If you have a contract that specifies what the concrete ultimate strength was supposed to be you are in good shape otherwise things could get very dicey. He is full of BS saying that everyone adds water and that 1500 psi is okay. A high-strength topcoat is not going to solve anything. Assuming you have a well-documented contract as these are going to end up in court or you're going to get the entire thing replaced.
Msradell is offline   Reply With Quote
Old 09-20-2013, 09:21 AM   #19
World's Tallest Midget
Mort's Avatar
Rewards Points: 692
Your contractor is right about one thing. Everybody adds a ton of water, at least on homeowner jobs they do. I put 85 gallons of extra water in a 10 yard load a few weeks ago, I guarantee it's going to crack. But after the customer accepts the load, it isn't the mixer driver's decision anymore.
He is incorrect that 1500psi is enough. If the spec in the building code is 2500 or whatever it may be, he placed an inferior material, and you may have a case.
I hate signatures.
Mort is offline   Reply With Quote
Old 09-20-2013, 10:12 AM   #20
What is the purpose of adding all the extra unneeded water on homeowner projects? Especially if one knows it's going to cause cracks. I don't get the reasoning.
RoyalAcresRod is offline   Reply With Quote
Old 09-20-2013, 03:56 PM   #21
Rewards Points: 1,232
Because it is easier to place a 10" slump than a 5".
Advice is free, Lessons begin at 75 bucks an hour.
Tscarborough is offline   Reply With Quote
Old 09-21-2013, 04:21 PM   #22
Mort's Avatar
Rewards Points: 692
We have a winner. When bidding a job, a contractor makes the same amount of money whether he's there for hours sweating his ass off, or raking for a minute and then finishing and leaving. And he's betting that homeowners don't know anything about concrete so he can get away with it. And usually, he's right, otherwise they would've DIYed it.
Bamboo on modified concrete pad jhanson Flooring 0 10-08-2011 11:58 AM
Repairing cracks in concrete utility sink machouinard General DIY Discussions 3 08-20-2011 09:48 PM
Concrete cracks koos123 Building & Construction 1 04-22-2011 02:01 PM
concrete cracks Wiscbldr Building & Construction 15 04-19-2011 06:20 PM
