Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 10-13-2012, 06:46 PM   #1
Cracks in brick wall
I have a stair step crack in one of my exterior brick walls. A structural engineer looked at it, and found no evidence of foundation problems, etc. I recently purchased the house. I have been using a cold chisel and hammer to chip away the old mortar before tuck pointing. Do any of you professionals have a better/easier/faster way to do this?
bjturner is offline   Reply With Quote
Old 10-13-2012, 06:55 PM   #2
[quote=bjturner;1030207]I have a stair step crack in one of my exterior brick walls. A structural engineer looked at it, and found no evidence of foundation problems, etc. I recently purchased the house. I have been using a cold chisel and hammer to chip away the old mortar before tuck pointing. Do any of you professionals have a better/easier/faster way to do this?[/quote
A 4 or 4 and a half inch grinder with a masonary disc will make much shorter work of it.
Canarywood1 is offline   Reply With Quote
Old 10-13-2012, 07:43 PM   #3
The cut needs to be about 1/2 deep so there's enough in the crack to stay stuck.
Mist down the brick so it does not wick up the miosture in the morter.
If there's a more then a few spots that need to be repaired buy a morter bad, a pastery bag also works to apply it.
Make sure to not leave a bunch of loose morter on top of the brick. wipe it down with a damp rag.
Old 10-13-2012, 07:58 PM   #4
Concrete & Masonry
A 4" x .220" or .250" diamond tuckpointing blade in a handheld grinder would be my suggestion.......
jomama45 is offline   Reply With Quote
Old 10-13-2012, 10:25 PM   #5
Thanks a bunch fellas!
Old 10-14-2012, 04:01 AM   #6
When using a disc cutter, it's easy on the horizontal joints, but be careful when doing the vertical joints; it is very easy to nick the bricks immediately above and below the joint. I prefer to use hammer and chisel to cut out the verticals.
tony.g is offline   Reply With Quote
Old 10-14-2012, 10:22 AM   #7
That sounds like good advice, Tony. I kind of thought that might be an issue.
Old 11-26-2012, 07:18 PM   #8
These are about $39 at lowes. Any less expensive alternatives? Just wandering.
Squeakyhinge is offline   Reply With Quote
Old 11-27-2012, 01:06 AM   #9
you get what you pay for,,, 'less' would be a wax crayon of the right shade we use 1/4", 5/16", 3/8", 7/16", & 1/2" ranging in price from $ 50 to $ 225,,, $ 39 is cheap but that's the quality apron/vest stores sell jomama's a pro & we are also - knowing what are the 'right' tools separates us from bargain-hunting diy'ers,,, don't assume he, i, & any other contractor doesn't also look for value every time we spend/invest $$$
taxpayers voting for obama are as idiotic as chickens who voted for Col. Sanders !
if you hear it from a guy in the apron store, be VERY suspicious the mtl/method will work,,, when it time to build something together, they won't answer phones NOR help
itsreallyconc is offline   Reply With Quote
Capping a brick parapet wall jrschenck Roofing 2 08-21-2011 12:22 PM
Attaching Willow Screen to brick wall tripled Landscaping & Lawn Care 5 08-12-2011 07:46 AM
Moisture concerns building against a brick wall (PICTURES) aluminum13 Building & Construction 8 05-17-2011 09:07 AM
Help with Swing out door into Breezeway/garage Brick wall! wad2k Building & Construction 3 04-25-2010 06:45 PM
New opening in a brick veneer wall - installing new brick ties? GrantJohnson Building & Construction 3 01-28-2009 11:17 AM
