-   Concrete, Stone & Masonry (http://www.diychatroom.com/f105/)
-   -   Cracks in brick wall (http://www.diychatroom.com/f105/cracks-brick-wall-159955/)
bjturner 10-13-2012 05:46 PM
I have a stair step crack in one of my exterior brick walls. A structural engineer looked at it, and found no evidence of foundation problems, etc. I recently purchased the house. I have been using a cold chisel and hammer to chip away the old mortar before tuck pointing. Do any of you professionals have a better/easier/faster way to do this?
Canarywood1 10-13-2012 05:55 PM
[quote=bjturner;1030207]I have a stair step crack in one of my exterior brick walls. A structural engineer looked at it, and found no evidence of foundation problems, etc. I recently purchased the house. I have been using a cold chisel and hammer to chip away the old mortar before tuck pointing. Do any of you professionals have a better/easier/faster way to do this?[/quote
A 4 or 4 and a half inch grinder with a masonary disc will make much shorter work of it.
joecaption 10-13-2012 06:43 PM
The cut needs to be about 1/2 deep so there's enough in the crack to stay stuck.
Mist down the brick so it does not wick up the miosture in the morter.
If there's a more then a few spots that need to be repaired buy a morter bad, a pastery bag also works to apply it.
Make sure to not leave a bunch of loose morter on top of the brick. wipe it down with a damp rag.
jomama45 10-13-2012 06:58 PM
A 4" x .220" or .250" diamond tuckpointing blade in a handheld grinder would be my suggestion.......
bjturner 10-13-2012 09:25 PM
Thanks a bunch fellas!
tony.g 10-14-2012 03:01 AM
When using a disc cutter, it's easy on the horizontal joints, but be careful when doing the vertical joints; it is very easy to nick the bricks immediately above and below the joint. I prefer to use hammer and chisel to cut out the verticals.
bjturner 10-14-2012 09:22 AM
That sounds like good advice, Tony. I kind of thought that might be an issue.
Squeakyhinge 11-26-2012 06:18 PM
These are about $39 at lowes. Any less expensive alternatives? Just wandering.
stadry 11-27-2012 12:06 AM
you get what you pay for,,, 'less' would be a wax crayon of the right shade :laughing: we use 1/4", 5/16", 3/8", 7/16", & 1/2" ranging in price from $ 50 to $ 225,,, $ 39 is cheap but that's the quality apron/vest stores sell :( jomama's a pro & we are also - knowing what are the 'right' tools separates us from bargain-hunting diy'ers,,, don't assume he, i, & any other contractor doesn't also look for value every time we spend/invest $$$
