Cracks around inground pool. How do I repair?
Can you take a picture farther back showing more of the pool deck that is in pictures two through four. As for that white strip, it is there to allow the deck to move. My guess is that the section of deck that has cracked, was either not compacted when they backfilled after doing the pool, or has washed out.
I would get someone in to inspect both the deck and the pool, due to if you have a liner on your's, or have never replaced it if there is one, you do not know how the concrete under the liner looks. Call your local pool companies to have them come out and look at it, along with a company that does concrete work to tell if there are hidden problems under the deck.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : Now listen, Cadet. I've got a job for you. See this button? To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : Don't touch it! It's the History Eraser button, you fool! To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : So what'll happen? To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : That's just it. We don't know. Maybe something bad, maybe something good. I guess we'll never know, 'cause you're going to guard it. You won't touch it, will you?
