Cracks After Window Replacement - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 08-25-2012, 09:54 AM   #1
Cracks after window replacement
Hello all,
Last month I had 5 of my old wooden basement windows replaced by a contractor. New windows are of PVC. Some time ago I noticed vertical cracks in the foundation and some bricks above each window (see the attached pictures).
This house is quite old (70 years) and apparently the contractor did not pay attention that there was is no metal lintels.
What can be done to prevent further crack expansion?
Thank you in advance
Cracks after window replacement-img_6458.jpg   Cracks after window replacement-dsc01170.jpg
North2 is offline   Reply With Quote
Old 08-25-2012, 10:36 AM   #2
Civil Engineer
Rewards Points: 4,778
Did your contract include installation of lintels as part of the window replacement? If not, then what exactly is it you believe the contractor was supposed to do about the lack of lintels? It seems possible the cracks were there before the window replacement, maybe you did not notice them, because they are small and perhaps you were not looking for them. There should have been a steel or iron lintel above each window, so the obvious solution to minimize the potential for future cracking is to get the lintels installed, else live with the potential for movement and possible expansion of the existing cracks.
Daniel Holzman is online now   Reply With Quote
Old 08-25-2012, 10:40 AM   #3
Rewards Points: 13,724
Unless he removed them to get the window in I see no way installing a new window caused this.
There could very well be a rebar reinforced header over that window that's covered up with the stucco.
Old 08-25-2012, 11:23 AM   #4
Rewards Points: 582
This has become a common problem in the UK in the last 30 odd years as uPVC windows have been put in and timber ones removed.
The old timber windows would take the weight of the external brickwork without a lintel, but the plastic ones won't and the brickwork drops, often jamming up the casements or doors, or cracking the glass.
Nowadays when windows are replaced the work comes under Building Control and lintels must be intalled by the builder.
stuart45 is offline   Reply With Quote
Old 08-25-2012, 07:05 PM   #5
No, this was not included because until yesterday I had no idea what lintel is and if they are missing. Basically, I hired him to change windows. He gave me the price.
Shouldn't this be a responsibility of the contractor to identify problems like this and to advise the customer appropriately?
The old wooden frame was very thick and solid. I remember they had very hard time to remove it. May it be that it played a role of support istead of a lintel?
Here is a picture that I took at the installation time. I do not see any metal parts above the window.
Old 08-25-2012, 07:09 PM   #6
What is strange is that I had 5 windows replaced and now every of them has a crack like this.
I am 99% sure there was no cracks before as I visually inspected the foundation a couple of times per year.
Old 08-26-2012, 04:32 AM   #7
Rewards Points: 582
[quote=North2;996349]
It is here, as this is a common problem.
Timber windows can support loads that plastic can't.
quote]
Old 08-26-2012, 08:13 AM   #8
Rewards Points: 6,652
Looks to me that you have a stucco type finish. Would have nothing to do with the windows being replaced, you just noticed the surface cracks now, due to the replacing of the windows. Most likely those cracks have been there for some time, appear to not be enlarging any, so I would just seal with clear silicone and just check yearly to see if the surface material becomes loose, or the crack enlarges.
Old homes, especially the age of yours can take a long time to finish settling, and that crack for all we know, could have happened twenty years ago, and you just noticed it, due to the window replacement.
Old 08-26-2012, 09:29 AM   #9
Concrete & Masonry
Rewards Points: 568
There's most likely a precast concrete lintel over the windows, as there's no way I can see that old wood window frame carrying all of the weight above. From what i can see, the windows are one course below the top of foundation, which would allow plenty of room for the precast lintel.
jomama45 is offline   Reply With Quote
Old 08-26-2012, 09:52 AM   #10
Rewards Points: 2,516
Provide a photo of the outside but stand further back to get more of a view above the window.
Lintels can be replaced and added. Gonna cost though.
hammerlane is offline   Reply With Quote
Old 08-26-2012, 06:20 PM   #11
cheif outhouse engineer
Looks like a poured concrete wall foundation. No need for a lintel in this situation. While it is unlikely the window change has caused the crack, the crack does not appear to be more than cosmetic.
The old saying about two types of concrete comes to mind. If it really bothers you, you can grind out the crack and fill with your choice of caulk/mortar, but the repair will be as obvious as the crack and no more structually sound.
I don't think you can blame the window guy for the cracks as neither the old window or the new one was supporting significant weight.
dakzaag is offline   Reply With Quote
Old 08-26-2012, 07:06 PM   #12
dakzaag, what you and the others are seeing, is nothing more than a Stucco coating or Parging, not the actual brick that is under it. If you look at the top picture, you can tell that there are spider cracks all over the finish. Doubt that the actual wall has been compromised, and as I stated before, this can happen over a period of time.
All the OP can do, is make sure that the coating is sound, and if it isn't, either remove that facial treatment and have a contractor that knows how to apply a new finish coating if they wish.
basement replacement window 32"x24" slider LMHmedchem Windows and Doors 12 08-29-2012 11:23 AM
how to secure replacement casement window tambo Windows and Doors 5 08-10-2012 11:49 AM
Old replacement window jsfoltz Windows and Doors 1 08-26-2011 07:27 PM
Installing a Replacement Vinyl window with brick mold jlatulippe Carpentry 4 06-23-2011 02:05 PM
Window Replacement mark2741 Remodeling 5 07-21-2010 03:33 PM
