Cracked, Sunken Breezeway Floor... - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 07-29-2013, 06:59 PM   #1
RealRobD's Avatar
Cracked, sunken breezeway floor...
Leveled the stairs today, bringing them up about an inch.
I can't afford to tear old the old crete and pour new.
Can i just mix a wheelbarrow full of concrete and pour it in and level it out?
Between the blue and red line in the pic is about a 1/4" drop and from the red line to the furthest wall it's about a 1/2". So the entire floor won't need crete.
What type of surface preparation do I need to follow?
Floor was until today covered with a commercial carpeting, glued down but the old glue was pretty much dust lol.
RealRobD is offline   Reply With Quote
Old 07-29-2013, 07:23 PM   #2
Rewards Points: 582
we use 565 henry floor pro self leveling agent ..should work in your case....ben sr
The Following User Says Thank You to ben's plumbing For This Useful Post:
oh'mike (07-29-2013)
Old 07-29-2013, 07:26 PM   #3
DIY staff
Rewards Points: 7,174
That is to thin for concrete----you will need a self leveling compound or Feather Finish or other thin,strong bonding patch--
I'm not a concrete guy--just a tile setter----so if a concrete pro tells you I'm nuts---believe him (or her)
Old 07-30-2013, 07:57 PM   #4
Rewards Points: 4,454
ben, that's probably a 1" board holding up the steps so maybe its a 3/4" finished thickness,,, is that mtl strong enough for that thickness w/o cracking & no jnts ? ?
far's prep, 4" grinder & cup wheel then vacuum & vacuum again
Old 07-30-2013, 08:39 PM   #5
Rewards Points: 582
I would mix up some concrete and hand push it under the steps to fill the gap..just use leveling agent for floor only...i think the max thickness is about 1/2" ....ben sr
Old 07-30-2013, 09:50 PM   #6
RealRobD's Avatar
Half inch won't cut it.
The gap under the front of the steps is ~2" and 3" at the rear.
I guess I'll just go to depth and then feather.
It's going to be covered with padding and a commercial carpet. So if it's not perfect, no sweat.
Trying to figure out what might have cracked our tiled floor cdnNick Tiling, ceramics, marble 37 04-25-2013 12:27 PM
raise sunken floor dlwalla Remodeling 4 11-26-2012 09:27 AM
Cupping red oak floor rocks911 Flooring 9 02-10-2011 01:42 AM
Carpet in the basement Packer Backer Flooring 16 11-04-2008 12:19 AM
Laminate Floor in Sunken Room w/ Tile on Edge z0s01 Flooring 1 02-20-2007 11:44 PM
